ojnab
capsman issues when usng VLANs [wifiwave2) [SOLVED] (circumvented)
Thu Jan 11, 2024 11:13 pm
I'm trying to setup add a guest VLAN to a legacy config and I'm encountering issues when I use a VLAN on the master interface.
The legacy setup is using a CCR could series routerOS 6.44.6 to connect to the ISP over fibre with hosts untagged and tagged VLAN, and using an HAPax2 routerOS 7.12.1 with more hosts untagged and tagged VLAN. The CCR and HAP are bridged together. The CCR does all the DHCP and routing.
Then I purchased an Audience and reinstalled it with routerOS 7.12.1 so it could get its Wifi config from the HAP using capsman and both routers would be using the same wifiwave2. Everything works with OK with my WiFi clients untagged.
Next I tried to configure another VLAN for guest WiFI - but inevitably encountered the issue that you can't have a VLAN tagged slave wifi on an untagged master wifi because the slave interface can't join the bridge. (PS: I tried tagged master and untagged slave, same issue)
Here is that setup
[admin@HAP] > /interface/wifiwave2/configuration/print detail
Flags: X - disabled
 0   name="5ghz" ssid="privateSSID=5G" country=Switzerland security=sec1
 1   name="2ghz" ssid="privateSSID" country=Switzerland security=sec1
 2   name="5ghz-backend" mode=station-bridge ssid="privateSSID-5G" country=Switzerland security=sec1
     channel.band=5ghz-ac
 3   name="2ghz-backend" mode=station-bridge ssid="privateSSID" country=Switzerland security=sec1
     channel.band=2ghz-n
 4   name="5ghz-guest" ssid="guestSSID-5G" country=Switzerland security=sec2
     datapath.vlan-id=200
 5   name="2ghz-guest" ssid="guestSSID" country=Switzerland security=sec2
[admin@HAP] > /interface/wifiwave2/provisioning/print detail
Flags: X - disabled
 0   supported-bands=5ghz-ax action=create-enabled master-configuration=5ghz slave-configurations=5ghz-guest
 1   supported-bands=2ghz-ax action=create-enabled master-configuration=2ghz slave-configurations=2ghz-guest
 2   radio-mac=XXXXXXX supported-bands=5ghz-ac action=create-dynamic-enabled master-configuration=5ghz-backend
 3   supported-bands=2ghz-n action=create-dynamic-enabled master-configuration=2ghz slave-configurations=2ghz-guest
 4   supported-bands=5ghz-ac action=create-dynamic-enabled master-configuration=5ghz slave-configurations=5ghz-guest
 [admin@HAP] > /interface/wifiwave2/print detail
Flags: M - master; D - dynamic; B - bound; X - disabled, I - inactive, R - running
 0 M B  default-name="wifi2" name="ax2-2ghz" l2mtu=1560 mac-address=XXXXXXX arp-timeout=auto radio-mac=XXXXX configuration=2ghz
 1   B  name="ax2-2ghz-guest" l2mtu=1560 mac-address=XXXXXX arp-timeout=auto master-interface=ax2-2ghz configuration=2ghz-guest
 2 M BR default-name="wifi1" name="ax2-5ghz" l2mtu=1560 mac-address=XXXXXX arp-timeout=auto radio-mac=XXXXXX configuration=5ghz
 3   BR name="ax2-5ghz-guest" l2mtu=1560 mac-address=XXXXXX arp-timeout=auto master-interface=ax2-5ghz configuration=5ghz-guest
 4 MDB  name="cap-wifi1" mac-address=XXXXXX arp-timeout=auto radio-mac=XXXXXX configuration=2ghz
 5  DB  ;;; vlan-id configured, but interface does not support assigning vlans
        name="cap-wifi2" mac-address=XXXXXX arp-timeout=auto master-interface=cap-wifi1 configuration=2ghz-guest
 6 MDB  name="cap-wifi3" mac-address=XXXXX arp-timeout=auto radio-mac=XXXXXX configuration=5ghz
 7  DB  ;;; vlan-id configured, but interface does not support assigning vlans
        name="cap-wifi4" mac-address=1A:FD:74:FA:4D:D4 arp-timeout=auto master-interface=cap-wifi3 configuration=5ghz-guest
[admin@HAP] > /interface/bridge/port/print detail
Flags: X - disabled, I - inactive; D - dynamic; H - hw-offload
 3     ;;; defconf
       interface=ether5 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes
       auto-isolate=no restricted-role=no restricted-tcn=no pvid=1 frame-types=admit-all ingress-filtering=yes unknown-unicast-flood=yes
       unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no trusted=no multicast-router=temporary-query fast-leave=no
 4     ;;; defconf
       interface=ax2-5ghz bridge=bridge priority=0x20 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none
 5 I   ;;; defconf
       interface=ax2-2ghz bridge=bridge priority=0x30 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none
 7 I   interface=ax2-2ghz-guest bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none
 8 I   interface=ax2-5ghz-guest bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none
[admin@HAP] > /interface/wifiwave2/cap/print
as-value     file     interval     without-paging
[admin@WifiMikroTik] > /interface/wifiwave2/cap/print
             enabled: yes
  caps-man-addresses: 127.0.0.1
[admin@HAP] > /interface/wifiwave2/capsman/
remote-cap     edit     export     get     print     set
[admin@HAP] > /interface/wifiwave2/capsman/print
                   enabled: yes
                interfaces: bridge
            ca-certificate: auto
  require-peer-certificate: no
            upgrade-policy: suggest-same-version
  generated-ca-certificate: CAPsMAN-CA-XXXXXX
     generated-certificate: CAPsMAN-XXXXXX
[admin@HAP] > /interface/wifiwave2/capsman/remote-cap/print detail
 0 address="" identity="Audience-1" board-name="RBD25G-5HPacQD2HPnD" serial="XXXXX" version="7.12.1" base-mac=XXXX common-name="" state="Ok"
[admin@Audience-1] > /interface/wifiwave2/cap print
               enabled: yes
  discovery-interfaces: bridge
           certificate: none
    caps-man-addresses: XXXX,YYYY
      lock-to-caps-man: no
[admin@Audience-1] > /interface/wifiwave2/capsman/print
                   enabled: no
Now if I run command
/interface/wifiwave2/configuration/set datapath.vlan-id=100 numbers=0,1
and now capsman doesn't work, yet I can see that the Audience has connected from its MAC address in the registration table
 0 M B  default-name="wifi2" name="ax2-2ghz" l2mtu=1560 mac-address=XXXXX arp-timeout=auto radio-mac=XXXXXX configuration=2ghz
 1   B  name="ax2-2ghz-guest" l2mtu=1560 mac-address=XXXXXXX arp-timeout=auto master-interface=ax2-2ghz configuration=2ghz-guest
 2 M BR default-name="wifi1" name="ax2-5ghz" l2mtu=1560 mac-address=XXXXXX arp-timeout=auto radio-mac=XXXXXXX configuration=5ghz
 3   B  name="ax2-5ghz-guest" l2mtu=1560 mac-address=XXXXXX arp-timeout=auto master-interface=ax2-5ghz configuration=5ghz-guest
[admin@HAP] > /interface/wifiwave2/registration-table/print
Flags: A - AUTHORIZED
Columns: INTERFACE, SSID, MAC-ADDRESS, UPTIME, SIGNAL
#   INTERFACE  SSID             MAC-ADDRESS        UPTIME  SIGNAL
0 A ax2-5ghz   KensWifiLAN2_5G  XXXXXXX 1m29s   -58
[admin@HAP] >
PS: The Audience has both IP addresses of the HAP on the untagged and the VLAN 100 address
I cannot ping the Audience on either of its IP addresses either
What needs to be changed to get capsman to work?
ojnab
Re: capsman issues when usng VLANs (wifiwave2) {SOLVED] (circumvented)
Wed Jan 17, 2024 11:44 pm
I gave up on VLANs and used a separate bridge
Unfortunately I had problems with the bridge not routing to my boundary router (probably because untagged traffic was bridged to it)
The way I resolved the issue was after creating a bridge on the ax2 and the Audience I then created another bridge on the boundary router and linked them all together using EoIP on the untagged network.
[admin@boundary] interface eoip add name=eoip-ax2 remote-ip=192.168.0.2 tunnel-id=1
[admin@boundary] interface eoip add name=eoip-audience remote-ip=192.168.0.3 tunnel-id=2
[admin@boundary] interface bridge add guest-bridge frame-types=admit-only-untagged-and-priority-tagged vlan-filtering=yes
[admin@boundary] interface brdge port add bridge=guest-bridge interface=eoip-ax2
[admin@boundary] interface brdge port add bridge=guest-bridge interface=eoip-audience
[admin@boundary] ip address add interface=guest-bridge ... ip pool ... ip dhcp-server ... blah blah
[admin@ax2] interface eoip add name=eoip-ax2 remote-ip=192.168.0.1 tunnel-id=1
[admin@ax2] interface bridge add guest-bridge frame-types=admit-only-untagged-and-priority-tagged vlan-filtering=yes
[admin@ax2] interface brdge port add bridge=guest-bridge interface=eoip-ax2
[admin@ax2] interface wifiwave2 configuration unset numbers=3,4 datapath.vlan
[admin@ax2] interface wifiwave2 configuration set datapath.brigge=guest-bridge numbers=3,4
[admin@audience] interface eoip add name=eoip-audience remote-ip=192.168.0.1 tunnel-id=2
[admin@audience] interface bridge add guest-bridge frame-types=admit-only-untagged-and-priority-tagged vlan-filtering=yes
[admin@audience] interface brdge port add bridge=guest-bridge interface=eoip-audience
It's not a perfectly seamless switching between ax2 and audience, like it is on the primary untagged network but it's only for guests so I'm not too bothered about a 1-2 second drop before switching AP.
Users browsing this forum: Google [Bot], holvoetn, Metroiss, sinisa, synchro and 9 guests
