I've followed the manual instructions at https://help.mikrotik.com/docs/display/ROS/WiFi .
I first created a security profile such as:
Code: Select all
add name=my-authN authentication-types=wpa3-psk passphrase="xxxx" wps=disable
Code: Select all
add name=my-conf ssid=mySSID country="United Kingdom" security=my-authN
Code: Select all
add name=my-2ghz frequency=2437 width=20mhz
add name=my-5ghz frequency=5180 width=20/40/80mhz
Code: Select all
set wifi1 channel=my-2ghz configuration=my-conf disabled=no
set wifi2 channel=my-5ghz configuration=my-conf disabled=no
It just doesn't work. The WiFi APs never go live.
BUT, if I go into the GUI for security, open my-authN and click on each item, the text goes from grey to black (with exactly the same setting). If I then go into configuration, open my-conf and click on each item, the text goes from grey to black.
Suddenly it all works.
But most odd - /interface/wifi/actual-configuration is 100% unchanged
If I delete everything and not bother with the configuration approach and just enter :
Code: Select all
set wifi1 disabled=no configuration.country="United Kingdom" configuration.ssid=mySSID security.authentication-types=wpa2-psk security.passphrase="xxxx"
I've now repeated it twice, and it behaves the same way... I can't see why this behaviour happens
