I tried using the new "back to home" app, and this peer was automatically created. I cannot remove it, nor can I remove a related NAT entry nor a related filter rule. I understand that the dynamic entries are created and removed automatically, and that they have a parent item, but I don't know how to locate the parent item to remove it. I am not able to set up a new tunnel with Back to Home at this point (it keeps adding new peers, which can easily be removed, but no new WG instance.
Any ideas? Thanks!
