I'm trying to apply configuration from here: https://help.mikrotik.com/docs/display/ ... ionexample:
(CAPs that support wifi-qcom-ac package and section below as well), but seems its not working as it described (or I miss something)
Seems it creates interfaces for ssid's which should be static, also that section:
/interface wifi
set [ find default-name=wifi1 ] configuration.manager=capsman disabled=no
set [ find default-name=wifi2 ] configuration.manager=capsman disabled=no
add disabled=no master-interface=wifi1 name=wifi21
add disabled=no master-interface=wifi2 name=wifi22
is deleted after I click on provision, after provision is not possible to create new static interface either. I dont understand what is going on.
capsman and wifi config:
Code: Select all
/interface wifi cap
set caps-man-addresses=127.0.0.1 certificate=request enabled=yes \
lock-to-caps-man=yes slaves-static=yes
/interface wifi capsman
set ca-certificate=auto certificate=auto enabled=yes package-path="" \
require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled comment=5ghz disabled=no \
master-configuration=lan slave-configurations=guest supported-bands=\
5ghz-ac
add action=create-dynamic-enabled comment=2.4ghz disabled=no \
master-configuration=lan slave-configurations=iot,guest supported-bands=\
2ghz-n
/interface wifi datapath
add bridge=bridge disabled=no name=lan
add bridge=bridge disabled=no name=guest vlan-id=1026
add bridge=bridge disabled=no name=iot vlan-id=1025
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=lan wps=disable
add authentication-types=wpa2-psk disabled=no group-encryption=ccmp name=iot \
wps=disable
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=guest wps=disable
/interface wifi configuration
add channel.skip-dfs-channels=disabled country=Hungary datapath=lan disabled=\
no manager=capsman name=lan security=lan ssid=teszt
no hide-ssid=yes manager=capsman name=iot security=iot ssid=teszt-iot
no manager=capsman name=guest security=guest ssid=teszt-guest
Code: Select all
add admin-mac=74:4D:28:AB:C7:EB auto-mac=no comment=defconf name=bridge \
port-cost-mode=short vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan-guest vlan-id=1026
add interface=bridge name=vlan-iot vlan-id=1025
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 \
internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 \
add bridge=bridge interface=wifi3 pvid=1025
add bridge=bridge interface=wifi4 pvid=1026
add bridge=bridge interface=wifi5 pvid=1026
rsc is attached..
