I have recently bought a CRS326-24G-2S+ for home and the excitement about so many configuration options by far outweighs the complexity challenges.
The CRS326 will mainly be used as switch and Inter-VLAN-Router, still I want to be able to use it also for some Internet access. As for the internet connection, I want to be completely independent from the features the ISP router provides. My internet connection is 1000/50 Mbit/s Vodafone Cable with Dual Stack (proper public IPv6 and proper public IPv4) which I guess is very good considering that I live in a 3rd world country where the internet is still Neuland for most people. My ISP router is a CGA4233DE which works ok and reliably but is really shitty regarding its feature set. It does not even support static routes or prefixes. I know that I could use it in Bridge Mode as modem, but I want to leave it as router as for now with all the downsides this can have.
Interface ether24 is connected to the ISP router. Setting up IPv4 internet connectivity was really easy: Assigned 192.168.0.5/24 to ether24 with the ISP router 192.168.0.2 as default gw.
Now, finally to the problem I have. I cannot get IPv6 internet connectivity working at all.
What I did:
Code: Select all
/ipv6 settings
set accept-router-advertisements=yes forward=no # forwarding will be needed later
/ipv6 dhcp-client
add add-default-route=yes interface=ether24 request=address
The result is that the ISP router assigns 2 global IPv6 addresses (I guess 1 via DHCP and 1 via SLAAC) with default gw (I removed the link-local addresses as they contain the MAC):
Code: Select all
/ipv6/address print
Flags: X - DISABLED, D - DYNAMIC; G - GLOBAL, L - LINK-LOCAL
Columns: ADDRESS, INTERFACE, ADVERTISE
# ADDRESS INTERFACE ADVERTISE
0 DL fe80::aaaa:bbbb:cccc:dddd/64 ether24 no
1 DG 2a02:810c:880:5dcc:4675:867b:8ebf:596a/128 ether24 no
2 DG 2a02:810c:880:5dcc:4aa9:8aff:fef7:3e45/64 ether24 no
/ipv6/route print
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, d - DHCP, g - SLAAC; H - HW-OFFLOADED
; + - ECMP
Columns: DST-ADDRESS, GATEWAY
DST-ADDRESS GATEWAY
DAg + ::/0 fe80::eeee:ffff:gggg:hhhh%ether24
DAd + ::/0 fe80::eeee:ffff:gggg:hhhh%ether24
DAc 2a02:810c:880:5dcc::/64 ether24
DAc 2a02:810c:880:5dcc:4675:867b:8ebf:596a/128 ether24
DAc fe80::%ether24/64 ether24
This looks OK to me and looks the same as on my ThinkPad when I connect directly to the ISP router.
Code: Select all
ip -6 addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 state UNKNOWN qlen 1000
inet6 ::1/128 scope host
valid_lft forever preferred_lft forever
4: wlp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 state UP qlen 1000
inet6 2a02:810c:880:5dcc:9ac3:551:7cfd:653d/128 scope global dynamic noprefixroute
valid_lft 604779sec preferred_lft 604779sec
inet6 2a02:810c:880:5dcc:e856:8514:eb8f:c8aa/64 scope global dynamic noprefixroute
valid_lft 86401sec preferred_lft 43201sec
inet6 fe80::iiii:jjjj:kkkk:llll/64 scope link noprefixroute
ip -6 route
::1 dev lo proto kernel metric 256 pref medium
2a02:810c:880:5dcc:9ac3:551:7cfd:653d dev wlp3s0 proto kernel metric 600 pref medium
2a02:810c:880:5dcc::/64 dev wlp3s0 proto ra metric 600 pref medium
fe80::/64 dev wlp3s0 proto kernel metric 1024 pref medium
default via fe80::eeee:ffff:gggg:hhhh dev wlp3s0 proto ra metric 600 pref medium
Still, I have no IPv6 internet at all, cannot even ping the Google DNS while it works easily on the ThinkPad with the same configuration.
Code: Select all
/ping address=2001:4860:4860::8888 interface=ether24
SEQ HOST SIZE TTL TIME STATUS
0 2001:4860:4860::8888 timeout
1 2001:4860:4860::8888 timeout
2 2001:4860:4860::8888 timeout
3 2001:4860:4860::8888 timeout
I can, however, ping the IPv6 default gw which is the link-local address of the ISP router, so IPv6 basically works:
Code: Select all
/ping address=fe80::eeee:ffff:gggg:hhhh interface=ether24
0 fe80::eeee:ffff:gggg:hhhh 56 64 1ms149us echo reply
1 fe80::eeee:ffff:gggg:hhhh 56 64 1ms383us echo reply
What am I doing wrong?
