sharkys
Wifi client DNSA-141 disconnects without obvious reason, prefer AP in longer distance
Fri Feb 02, 2024 12:07 pm
might have similar issue like described here - viewtopic.php?p=1019015#p1019015 - but decided to open new thread, as I have some more background info and not sure how to address it. I'm in contact with Mikrotik support for 3 weeks but so far no progress, so let's see if Community experts could help.
Can you help me to understand why client 28:24:FF:3E:0E:B3 disconnect with signal -66dBm ? This client is based on module DNSA-141 - 2.4GHz - https://downloads.codico.com/misc/Newsl ... SA-141.pdf (WLAN module of HaasSohn Kettle). Enabling DEBUG logs do not shows any details. On previous setup with Ubiquity based access points, I didn’t have those problems at all. I have tried all different setting however this combination is required to have all aprox. 53 clients connecting.
Also for some reason, the client 28:24:FF:3E:0E:B3 never connects to MikrotikDOWN, which is actually closer than MikrotikUP, is it maybe some hidden incompatibility ?
After Mikrotik support replied, we found the dependency on enabled AX - as soon as I disable it, client connects even to closer MikrotikDOWN and seems to be more stable but we don't know why, definitively do not want to get dir of AX. Yet also can't replace Wifi module in the kettle .
I tried to debug it further, with sniffer I see quite strange behavior :
Why ipv6 broadcast and why it prefer/connect then to AP, which is in bigger distance ? Both APs has the same configuration trough CAPSMAN.
Have you seen anything like that ? Btw also tried different firmware version, including latest beta 8
Relevant configs part from two APs and main router, APs are connected by cable to the main router:
MikrotikUP
# 2024-02-02 09:37:09 by RouterOS 7.14beta8
# software id = 7VU7-Q2XU
# model = cAPGi-5HaxD2HaxD
add add-dhcp-option82=yes admin-mac=78:9A:18:51:0E:5D auto-mac=no \
    dhcp-snooping=yes name=bridge port-cost-mode=short protocol-mode=none
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment=LAN
/interface wifi
# managed by CAPsMAN
# mode: AP, SSID: apSOME, channel: 5240/ax/eeeC
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap \
    disabled=no
# mode: AP, SSID: apSOME, channel: 2412/ax/Ce
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap \
    disabled=no
add name=WAN
add name=LAN
/ip smb smb-user
set [ find default=yes ] disabled=yes read-only=yes
add bridge=bridge comment=WAN interface=ether1 internal-path-cost=10 \ path-cost=10 \ trusted=yes
add bridge=bridge comment=LAN interface=ether2 internal-path-cost=10 \ path-cost=10 \ trusted=yes
add bridge=bridge interface=wifi1 internal-path-cost=10 path-cost=10 trusted=\
    yes
add bridge=bridge interface=wifi2 internal-path-cost=10 path-cost=10 trusted=\
    yes
/interface bridge settings
set use-ip-firewall-for-pppoe=yes use-ip-firewall-for-vlan=yes
set icmp-timeout=30s loose-tcp-tracking=no udp-stream-timeout=2m
set discover-interface-list=all
/ip settings
set arp-timeout=20m
/ipv6 settings
set disable-ipv6=yes forward=no
/interface detect-internet
set detect-interface-list=all lan-interface-list=LAN wan-interface-list=WAN
add interface=ether1 list=WAN
add interface=bridge list=LAN
/interface wifi cap
set certificate=CAP-789A18510E5C discovery-interfaces=all enabled=yes \
    lock-to-caps-man=yes
/interface wifi capsman
set package-path="" require-peer-certificate=no upgrade-policy=none
/ip dhcp-client
/ip dhcp-relay
add dhcp-server=10.0.0.1 disabled=no interface=ether1 local-address=10.0.0.3 \
    name=relay1
set allow-remote-requests=yes
/ip firewall service-port
set h323 ports=1720
set sip ports=5060,5061,500,4500,5222,3478,80,443 sip-timeout=3m
/ip service
set www-ssl disabled=no
/ip smb smb-share
set [ find default=yes ] directory=/pub
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
/ipv6 nd
/system clock
set time-zone-name=Europe/Prague
/system identity
set name=Mikrotik_UP
MikrotikDOWN
# 2024-02-02 09:37:14 by RouterOS 7.14beta8
# software id = 51IY-2PA5
add add-dhcp-option82=yes admin-mac=78:9A:18:51:0E:0C auto-mac=no \
/interface wifi
    disabled=no
# mode: AP, SSID: apSOME, channel: 2437/ax/Ce
    disabled=no
add name=WAN
add name=LAN
/ip smb smb-user
    yes
    yes
/ip settings
set arp-timeout=20m
/ipv6 settings
/interface wifi cap
set certificate=CAP-789A18510E0C discovery-interfaces=all enabled=yes \
/ip dhcp-client
/ip dhcp-relay
add dhcp-server=10.0.0.1 disabled=no interface=ether1 local-address=10.0.0.2 \
    name=relay1
set h323 ports=1720
/ip service
/ip smb smb-share
/ip upnp
/ip upnp interfaces
/ipv6 nd
/system clock
/system identity
set name=Mikrotik_DOWN
Main router
# 2024-02-02 09:36:53 by RouterOS 7.14beta8
# software id = S5MY-N4ZX
# model = RB960PGS
add admin-mac=78:9A:18:4D:75:6F arp=proxy-arp auto-mac=no name=bridge
add name=WAN
add name=LAN
/interface lte apn
/interface wifi datapath
add bridge=bridge disabled=no name=cadp
/interface wifi steering
add disabled=no name=steeringMK neighbor-group=dynamic-apSOME-32cba8ab rrm=\
    yes wnm=yes
/interface wifi configuration
add channel.band=2ghz-ax .width=20/40mhz country=Czech datapath=cadp \
    disabled=no dtim-period=2 mode=ap name=Config24_down qos-classifier=\
    priority security.authentication-types=wpa2-psk .encryption="" .ft=yes \
    .ft-mobility-domain=0x1ADF .ft-over-ds=yes .management-protection=\
    disabled ssid=apSOME steering=steeringMK steering.neighbor-group=\
    dynamic-apSOME-32cba8ab .rrm=yes .wnm=yes
add channel.band=5ghz-ax .frequency=5240 .skip-dfs-channels=10min-cac .width=\
    20/40/80mhz country=Czech datapath=cadp disabled=no mode=ap name=\
    "Cong5Ghz up" qos-classifier=priority security.authentication-types=\
    wpa2-psk .encryption="" .ft=yes .ft-mobility-domain=0x1ADF .ft-over-ds=\
    yes ssid=apSOME steering=steeringMK steering.neighbor-group=\
    disabled=no dtim-period=2 mode=ap name=Config24_up qos-classifier=\
    "Cong5Ghz down" qos-classifier=priority security.authentication-types=\
/interface wifi
add configuration="Cong5Ghz up" configuration.mode=ap disabled=no name=\
    "cap-wifi1 5GHz DOWN" radio-mac=78:9A:18:51:0E:0E
add configuration=Config24_down configuration.mode=ap disabled=no name=\
    "cap-wifi2 2,4GHz DOWN" radio-mac=78:9A:18:51:0E:0F
    "cap-wifi2 5GHz UP" radio-mac=78:9A:18:51:0E:5E
add configuration=Config24_up configuration.mode=ap disabled=no name=\
    "cap-wifi4 2,4GHz UP" radio-mac=78:9A:18:51:0E:5F
add name=dhcp ranges=10.0.0.2-10.0.0.254
add add-arp=yes address-pool=dhcp always-broadcast=yes interface=bridge
/ip smb smb-user
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
add bridge=bridge comment="AP DOWN" ingress-filtering=no interface=ether2 \
    internal-path-cost=10 path-cost=10 trusted=yes
add bridge=bridge comment="AP UP" ingress-filtering=no interface=ether3 \
/ip settings
set arp-timeout=20m max-neighbor-entries=8192
/ipv6 settings
set disable-ipv6=yes forward=no max-neighbor-entries=8192
set detect-interface-list=WAN internet-interface-list=WAN lan-interface-list=\
set ca-certificate=WiFi-CAPsMAN-CA-789A184D756E certificate=\
    WiFi-CAPsMAN-789A184D756E enabled=yes interfaces=bridge package-path="" \
    require-peer-certificate=yes upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled comment="2,4GHz Mikrotik UP" disabled=no \
    master-configuration=Config24_up radio-mac=78:9A:18:51:0E:5F
add action=create-dynamic-enabled comment="5Ghz Mikrotik UP" disabled=no \
    master-configuration="Cong5Ghz up" radio-mac=78:9A:18:51:0E:5E
add action=create-dynamic-enabled comment="5GHz Mikrotik DOWN" disabled=no \
    master-configuration="Cong5Ghz down" radio-mac=78:9A:18:51:0E:0E
add action=create-dynamic-enabled comment="2,4GHz Mikrotik DOWN" disabled=no \
    master-configuration=Config24_down radio-mac=78:9A:18:51:0E:0F
/interface wireless cap
set bridge=bridge caps-man-addresses=127.0.0.1
add address=10.0.0.1/24 interface=bridge network=10.0.0.0
add address=10.0.0.0/24 dns-server=10.0.0.1 domain=local gateway=10.0.0.1 \
    netmask=24
set allow-remote-requests=yes use-doh-server=\
    https://cloudflare-dns.com/dns-query verify-doh-cert=yes
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
/system identity
set name=RouterMK
/system logging
add disabled=yes topics=wireless,debug
Thank you for any help !
sharkys
Re: Wifi client DNSA-141 disconnects without obvious reason, prefer AP in longer distance
Sat Feb 10, 2024 12:01 am
Just found interesting thing... when I restart MikrotikDOWN, when I disable ethernet port 2, to which MikrotikDOWNis connected, I loose connectivity not only to the MikrotikDOWN itself but main Mikrotik as well ? Even the device, which I'm testing it from, is connected via Ethernet switch to port Ether1. When I do the same with MikrotikUP, clients reconnects to MikrotikDOWN and ethernet connectivity is untouched....
Any idea why is this happening ?
sharkys
Sat Feb 10, 2024 12:04 am
sharkys
Sat Feb 10, 2024 12:35 am
OK I swapped Eth1 with Eth4 - same behavior. ...
sharkys
Sat Feb 10, 2024 12:09 pm
really, no thoughts at all ? :(
sharkys
Sun Feb 11, 2024 12:36 am
Answering myself, after I cleared out all ARP entries, seems disabling port for MikrotikDOWN do not influence connectivity to the main router MikrotikMK anymore.
sharkys
Tue Feb 20, 2024 11:16 pm
Strange, reset both APs and suddenly, that client is much more stable and keep connecting even to the MikrotikDOWN, I don't understand that.
BUT - newly I have problem with : :-| :-| :-|
 19:56:11 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 19:56:11 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 19:56:37 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 19:56:40 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 19:56:40 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 20:20:20 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 20:20:24 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 20:20:24 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 20:21:08 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 20:21:11 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 20:21:11 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 20:44:30 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 20:44:34 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 20:44:34 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 20:54:44 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 20:54:48 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 20:54:48 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 20:55:18 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 20:55:23 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 20:55:23 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 21:04:43 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 21:04:48 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 21:04:48 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 21:14:48 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 21:14:51 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 21:14:51 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 21:21:19 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 21:21:23 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 21:21:23 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 21:34:57 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 21:35:01 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 21:35:01 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 21:37:39 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 21:37:44 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 21:37:44 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 21:44:22 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 21:44:26 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 21:44:26 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 21:47:06 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 21:47:10 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 21:47:10 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 21:47:28 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
 21:47:32 caps,info selected CAPsMAN RouterMK@78:9A:18:4E:45:7F%*6
 21:47:32 caps,info connected to RouterMK@78:9A:18:4E:45:7F%*6
 22:02:47 caps,info disconnected from RouterMK@78:9A:18:4E:45:7F%*6, failed to connect
That brings instability also to all others Wifi clients. It's occurring randomly, on BOTH APs, both are connected via Ethernet.
sharkys
Mon Mar 04, 2024 1:32 am
So when I recreate the whole Wifi config manually and disabled Capsman, suddenly Wifi is stable and keep connected for days, so it's something caused by CAPSMAN.
Is there any way to foce CAPSMAN not to restart Wifi when loosing connectivity with CAP ?
mkx
Mon Mar 04, 2024 8:58 am
No.
sharkys
Mon Mar 04, 2024 9:27 am
Thank you for reply, however issue is not solved... I still need to figure out, why Capsman is loosing connection, on two different APs, randomly, connected via different Ethernet cable etc.
Trying debug logging, to find out more.
sharkys
Thu Mar 07, 2024 10:38 am
I have key discovery. On 7.15beta4, no improvements BUT - CAPSMANN fails or better to say, start disconnecting after every aprox. 10 hours
When I restart both APs before that time, it's stable for another 9-10 hours.
Any thoughts on that ?
sharkys
Fri Mar 15, 2024 1:00 pm
I set both APs without CAPSMAN, the problems are gone, even fast roaming is working, just from time to time getting complete "no data" connection randomly after roaming (sometimes after 10 seconds, sometimes after 30). So far I was not able to find the reason :-(
Users browsing this forum: nizce and 6 guests
