RB3011 CAPSMAN
Code: Select all
/interface wifi
# SSID not set
add configuration.mode=ap disabled=no name=cap-wifi1 radio-mac=\
78:9A:18:F5:4D:F4
# SSID not set
add configuration.mode=ap disabled=no name=cap-wifi2 radio-mac=\
78:9A:18:F5:4D:F5
/interface wifi channel
add band=5ghz-ax disabled=no frequency=5160-5805 name=5-ax skip-dfs-channels=\
all
add band=2ghz-ax disabled=no name=2-ax skip-dfs-channels=all width=\
20/40/80mhz
add band=2ghz-n disabled=no name=2-n skip-dfs-channels=all width=20mhz
/interface wifi datapath
add disabled=no name=main vlan-id=20
add client-isolation=yes disabled=no name=guest vlan-id=30
/interface wifi configuration
add channel=2-ax country=Czech datapath=main disabled=no mode=ap name=\
main_wifi_conf security.ft=yes .ft-over-ds=yes ssid=test
add channel=2-n country=Czech datapath=guest disabled=no mode=ap name=\
guest_wifi_conf security.ft=yes .ft-over-ds=yes ssid=test_guest
/interface wifi capsman
set enabled=yes interfaces=all package-path="" require-peer-certificate=no \
upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=\
main_wifi_conf radio-mac=00:00:00:00:00:00 supported-bands=2ghz-n
Code: Select all
# 2024-02-05 17:27:53 by RouterOS 7.13.1
# software id = M21E-SV82
# model = cAPGi-5HaxD2HaxD
# serial number = HFK09BJT8NT
add admin-mac=78:9A:18:F5:4D:F2 auto-mac=no comment=defconf name=bridgeLocal \
vlan-filtering=yes
/interface vlan
add interface=bridgeLocal name=vlan10-infrastructure vlan-id=10
add bridge=bridgeLocal comment=defconf disabled=no name=capdp
/interface wifi
# managed by CAPsMAN
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap \
datapath=capdp datapath.bridge=bridgeLocal disabled=no
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap \
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
/interface bridge vlan
add bridge=bridgeLocal tagged=ether1,bridgeLocal vlan-ids=10
add bridge=bridgeLocal tagged=ether1,bridgeLocal vlan-ids=20
add bridge=bridgeLocal tagged=ether1,bridgeLocal vlan-ids=30
/interface wifi cap
set discovery-interfaces=all enabled=yes slaves-datapath=capdp
/ip dhcp-client
add comment=defconf disabled=yes interface=bridgeLocal
add interface=vlan10-infrastructure
/system clock
set time-zone-name=Europe/Prague
/system logging
add topics=caps
/system note
set show-at-login=no
