Thanks for help mates,
yes I try to figure out myself if I can not load you, in the end I was succeed so there were no reason to post config file with sensible datas inside.
Now I post it, I really hope you see what I can't (
# 2024-02-07 12:10:20 by RouterOS 7.12.1
# software id = YH2P-AUKZ
# model = RBD53iG-5HacD2HnD
# serial number = <edit>
/caps-man channel
add band=2ghz-b/g/n extension-channel=Ce frequency=2427 name=channel3
add band=2ghz-b/g/n extension-channel=Ce frequency=2412 name=channel1 tx-power=\
0
add band=5ghz-a/n/ac frequency=5320 name=channel64
add admin-mac=18:FD:74:64:B7:B6 auto-mac=no comment=defconf name=bridge
add name=bridge-Denrozhdeniya
add name=bridge-public
/interface wireless
# managed by CAPsMAN
# channel: 2427/20-Ce/gn(27dBm), SSID: Vino di Vino, local forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=MikroTik-64B7BA wireless-protocol=802.11
# channel: 5320/20-eeCe/ac/P(14dBm), SSID: Vino di Vino, local forwarding
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
country=russia4 disabled=no distance=indoors frequency=auto installation=\
indoor mode=ap-bridge ssid=TEST wireless-protocol=802.11
/interface wireguard
add listen-port=57981 mtu=1420 name=VPN-Wireguard
/interface vlan
add interface=ether1 name=vlan2-Public vlan-id=2
add interface=ether1 name=vlan4-Denrozhdeniya vlan-id=4
/caps-man datapath
add bridge=bridge client-to-client-forwarding=yes local-forwarding=yes name=\
Bridge
add bridge=bridge-public name=Bridge-public
add bridge=bridge-Denrozhdeniya client-to-client-forwarding=yes \
local-forwarding=no name=bridge-Denrozhdeniya
/caps-man configuration
add datapath=Bridge-public name="2.4Ghz Sala-Public" ssid="VinoDiVino FreeWiFi"
add datapath=Bridge-public name="5Ghz Sala-Public" ssid="VinoDiVino FreeWiFi"
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm \
group-key-update=1h name=Vinodivino
add name=Free
group-key-update=1h name=vdv
add channel=channel3 country=canada datapath=Bridge mode=ap name="2.4Ghz Sala" \
security=Vinodivino ssid="Vino di Vino"
add channel=channel1 channel.tx-power=14 country=russia4 datapath=Bridge \
installation=any mode=ap name="2.4GHz Ufficio" security=Vinodivino ssid=\
"Vino di Vino"
add channel=channel64 country=russia4 datapath=Bridge mode=ap name="5Ghz Sala" \
add datapath=Bridge name="2.4Ghz Ufficio-vdv" security=vdv ssid=vdv
add datapath=bridge-Denrozhdeniya datapath.bridge=bridge-Denrozhdeniya name=\
"2.4Ghz Sala-Denrozhdeniya" security=Free ssid="S Dnem Rozhdeniya!"
"5Ghz Sala-Denrozhdeniya" security=Free ssid="S Dnem Rozhdeniya!"
add comment=defconf name=WAN
add comment=defconf name=LAN
/ppp profile
add dns-server=8.8.8.8,1.1.1.1 local-address=192.168.2.1 name=OVPN2 \
remote-address=192.168.2.2 use-compression=no use-encryption=yes use-ipv6=\
no
add dns-server=8.8.8.8,1.1.1.1 local-address=192.168.2.1 name=OVPN3 \
remote-address=192.168.2.3 use-compression=no use-encryption=yes use-ipv6=\
no
add dns-server=8.8.8.8,1.1.1.1 local-address=192.168.2.1 name=OVPN4 \
remote-address=192.168.2.4 use-compression=no use-encryption=yes use-ipv6=\
no
add dns-server=8.8.8.8,1.1.1.1 local-address=192.168.2.1 name=OVPN5 \
remote-address=192.168.2.5 use-compression=no use-encryption=yes use-ipv6=\
no
add dns-server=8.8.8.8,1.1.1.1 local-address=192.168.2.1 name=OVPN \
no
add dns-server=8.8.8.8,1.1.1.1 local-address=192.168.2.1 name=OVPN6 \
remote-address=192.168.2.6 use-compression=no use-encryption=yes use-ipv6=\
no
/routing table
add disabled=no fib name=Bibione
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration="2.4Ghz Sala" \
name-format=identity radio-mac=18:FD:74:64:B7:BA slave-configurations=\
add action=create-dynamic-enabled master-configuration="5Ghz Sala" name-format=\
identity radio-mac=18:FD:74:64:B7:BB slave-configurations=\
"5Ghz Sala-Public"
add action=create-dynamic-enabled master-configuration="2.4GHz Ufficio" \
name-format=identity radio-mac=08:55:31:1A:0F:94
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=ether1
add bridge=bridge-public interface=vlan2-Public
add bridge=bridge-Denrozhdeniya interface=vlan4-Denrozhdeniya
/ipv6 settings
set disable-ipv6=yes
add comment=defconf disabled=yes interface=ether1 list=WAN
add interface=VPN-Wireguard list=LAN
/interface ovpn-server server
set auth=sha1 certificate=certificato cipher=aes256-cbc default-profile=OVPN2 \
enabled=yes max-mtu=1400 port=44301
/interface wireguard peers
add allowed-address=192.168.97.2/24 client-address=192.168.97.2/24 client-dns=\
8.8.8.8 interface=VPN-Wireguard private-key=\
"aJAtji26KI/N9nQhmEOJ25o5vr8an3FhdMNBUBzRvHg=" public-key=\
"USIWUhywN9gORE1dTsTtABhNPRtLT068tiVnXXdc/Uc="
/interface wireless cap
set bridge=bridge caps-man-addresses=127.0.0.1 enabled=yes interfaces=\
wlan1,wlan2
add address=192.168.1.254/24 comment=defconf interface=bridge network=\
192.168.1.0
add address=192.168.97.1/24 interface=VPN-Wireguard network=192.168.97.0
/ip dhcp-client
add disabled=yes interface=bridge-Denrozhdeniya
192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
add address=192.168.0.2 match-subdomain=yes name=vdv
established,related,untracked
invalid disabled=yes
add action=accept chain=input dst-address=192.168.1.254 dst-port=57981 \
protocol=udp
add action=accept chain=forward dst-port=8291 protocol=tcp
disabled=yes in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new disabled=yes \
in-interface-list=WAN
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address=!192.168.0.0/16 \
new-routing-mark=Bibione passthrough=yes src-address=192.168.101.100
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
ipsec-policy=out,none src-address=192.168.97.0/24
add action=src-nat chain=srcnat comment=Wireguard disabled=yes src-address=\
192.168.97.2 to-addresses=192.168.1.254
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-table=main \
suppress-hw-offload=no
add disabled=no dst-address=192.168.101.0/24 gateway=192.168.2.3 routing-table=\
main suppress-hw-offload=no
add disabled=no dst-address=192.168.88.0/24 gateway=192.168.2.2 routing-table=\
add disabled=yes distance=5 dst-address=0.0.0.0/0 gateway=192.168.2.2 pref-src=\
"" routing-table=Bibione scope=30 suppress-hw-offload=no target-scope=10
add disabled=no dst-address=192.168.23.0/24 gateway=192.168.2.4 routing-table=\
/ip service
set winbox address=0.0.0.0/0
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
ipsec-ah
ipsec-esp
/ppp secret
add name=OVPN2 profile=OVPN2 service=ovpn
add name=OVPN3 profile=OVPN3 service=ovpn
add name=OVPN4 profile=OVPN4 service=ovpn
add name=OVPN5 profile=OVPN5 service=ovpn
add name=OVPN profile=OVPN
add name=OVPN6 profile=OVPN6 service=ovpn
/system clock
set time-zone-name=Europe/Moscow
/system identity
set name="WiFi Sala"
/system logging
add topics=caps
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=193.204.114.232
/system scheduler
add interval=1w name="Reboot monday" on-event="/system reboot" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=2023-02-20 start-time=06:00:00
/tool mac-server
/tool mac-server mac-winbox
[admin@WiFi Sala] >
