Similar issues here:
Unstable MAC Winbox connection
Winbox close connection in a loop
Cannot connect to hAP ac2 via WinBox using MAC address
Winbox mac-connect Windows 11 not working
Mikrotik winbox not connecting
Winbox dropping connection
Can't access RouterOS via mac address
The solutions posted in other threads I've tried so far:
- set static IP on PC
- enable Jumbo Frames 9014 in NIC properties
- disable all other network interfaces including Bluetooth/Wireless
- Tools->MAC Server is set to LAN
- update WinBox to latest version
- run WinBox as Administrator
- try WinBox64 as well as WinBox32 bit
- disable Windows built-in antivirus
- close all windows from previous sessions (in WinBox)
Edit, suggestions below and more I found elsewhere:
- set Windows network profile to private
- disable Windows firewall
- try with switch between the PC and the router
