# 2024-02-29 12:41:30 by RouterOS 7.13
# software id = xxxxx
# model = xxxxx
# serial number = xxxx
add name=Bridge_3_16 port-cost-mode=short
/interface l2tp-client
add allow=mschap1,mschap2 connect-to=xxxx.sn.mynetname.net disabled=no \
name=l2tp-VPN use-ipsec=yes user=MM
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-DATONO--2 \
user=PED_TELEM
/interface wireguard
add disabled=yes listen-port=14231 mtu=1420 name=MMCG_WG
add name="WAN Interface List"
/port
set 0 name=serial0
set 1 name=serial1
add bridge=Bridge_3_16 interface=ether3 internal-path-cost=10 path-cost=10
add bridge=Bridge_3_16 interface=ether4 internal-path-cost=10 path-cost=10
add bridge=Bridge_3_16 interface=ether5 internal-path-cost=10 path-cost=10
add bridge=Bridge_3_16 interface=ether6 internal-path-cost=10 path-cost=10
add bridge=Bridge_3_16 interface=ether7 internal-path-cost=10 path-cost=10
add bridge=Bridge_3_16 interface=ether8 internal-path-cost=10 path-cost=10
add bridge=Bridge_3_16 interface=ether9 internal-path-cost=10 path-cost=10
add bridge=Bridge_3_16 interface=ether10 internal-path-cost=10 path-cost=10
add bridge=Bridge_3_16 interface=ether11 internal-path-cost=10 path-cost=10
add bridge=Bridge_3_16 interface=ether12 internal-path-cost=10 path-cost=10
add bridge=Bridge_3_16 interface=ether13 internal-path-cost=10 path-cost=10
add bridge=Bridge_3_16 interface=ether14 internal-path-cost=10 path-cost=10
add bridge=Bridge_3_16 interface=ether15 internal-path-cost=10 path-cost=10
add bridge=Bridge_3_16 interface=ether16 internal-path-cost=10 path-cost=10
add interface=ether1 list="WAN Interface List"
add interface=ether2 list="WAN Interface List"
add interface=*14 list="WAN Interface List"
/interface wireguard peers
add allowed-address=0.0.0.0/0 disabled=yes endpoint-address=\
xxxxxx.sn.mynetname.net endpoint-port=13231 interface=MMCG_WG \
private-key="gCqIxdxx1xxxJIkIrtmoCN/pLYFhStrSrFxxxxx=" public-key=\
"YQiw4i/8PC827LdGDupXxx1qnrOwzWKd3exxxxx="
add address=192.168.4.10/24 interface=Bridge_3_16 network=192.168.4.0
add address=10.10.10.10/24 interface=MMCG_WG network=10.10.10.0
set servers=8.8.8.8,1.1.1.1
/ip firewall address-list
add address=23.88.192.0/19 comment=AFGHANISTAN list=CountryIPBlocks
add address=36.50.21.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=43.230.209.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=43.250.136.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=45.65.56.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=45.116.128.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=45.126.253.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=58.147.128.0/19 comment=AFGHANISTAN list=CountryIPBlocks
add address=59.153.124.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=61.5.192.0/20 comment=AFGHANISTAN list=CountryIPBlocks
add address=64.207.208.0/21 comment=AFGHANISTAN list=CountryIPBlocks
add address=64.224.144.0/20 comment=AFGHANISTAN list=CountryIPBlocks
add address=74.118.80.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=91.109.216.0/21 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.5.172.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.5.196.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.13.64.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.15.38.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.15.238.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.17.60.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.17.165.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.17.166.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.18.160.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.23.36.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.28.132.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.30.136.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.42.0.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.46.208.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.53.16.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.53.24.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.71.59.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.84.97.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.86.124.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.87.88.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.88.192.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.89.152.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.93.254.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.94.24.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.96.233.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.102.220.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.104.146.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.106.182.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.110.53.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.110.54.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.112.164.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.112.177.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.112.178.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.114.128.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.115.14.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.116.25.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.119.24.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.125.186.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.126.4.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.132.98.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.133.75.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.133.82.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.142.212.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.143.204.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.144.237.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.146.104.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.146.146.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.146.198.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.147.232.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.148.70.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.149.39.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.151.88.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.153.80.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.156.190.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.157.85.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.159.163.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.161.236.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.162.126.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.165.190.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.168.193.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.170.98.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.177.206.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.185.231.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.212.160.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.213.104.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.215.210.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.216.160.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.224.127.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.227.16.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.230.252.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.233.183.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.235.176.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.241.156.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.242.50.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.244.144.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.247.198.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.254.166.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=103.255.204.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=111.125.152.0/21 comment=AFGHANISTAN list=CountryIPBlocks
add address=116.204.160.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=116.204.240.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=116.206.188.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=117.55.192.0/21 comment=AFGHANISTAN list=CountryIPBlocks
add address=117.104.224.0/21 comment=AFGHANISTAN list=CountryIPBlocks
add address=119.59.80.0/21 comment=AFGHANISTAN list=CountryIPBlocks
add address=121.100.48.0/21 comment=AFGHANISTAN list=CountryIPBlocks
add address=121.127.32.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=121.127.34.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=121.127.37.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=121.127.38.0/23 comment=AFGHANISTAN list=CountryIPBlocks
add address=125.213.192.0/19 comment=AFGHANISTAN list=CountryIPBlocks
add address=137.59.120.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=149.54.0.0/17 comment=AFGHANISTAN list=CountryIPBlocks
add address=152.36.192.0/19 comment=AFGHANISTAN list=CountryIPBlocks
add address=163.47.160.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=175.106.32.0/19 comment=AFGHANISTAN list=CountryIPBlocks
add address=180.94.64.0/19 comment=AFGHANISTAN list=CountryIPBlocks
add address=180.222.136.0/21 comment=AFGHANISTAN list=CountryIPBlocks
add address=185.178.144.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=185.193.212.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=202.3.76.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=203.171.96.0/19 comment=AFGHANISTAN list=CountryIPBlocks
add address=203.174.27.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=203.215.32.0/20 comment=AFGHANISTAN list=CountryIPBlocks
add address=223.26.20.0/22 comment=AFGHANISTAN list=CountryIPBlocks
add address=5.206.232.0/21 comment=ALBANIA list=CountryIPBlocks
add address=31.22.48.0/20 comment=ALBANIA list=CountryIPBlocks
add address=31.41.33.0/24 comment=ALBANIA list=CountryIPBlocks
add address=31.44.64.0/20 comment=ALBANIA list=CountryIPBlocks
add address=31.171.152.0/21 comment=ALBANIA list=CountryIPBlocks
add address=31.222.40.0/21 comment=ALBANIA list=CountryIPBlocks
add address=37.26.64.0/21 comment=ALBANIA list=CountryIPBlocks
add address=37.26.80.0/21 comment=ALBANIA list=CountryIPBlocks
add address=37.35.64.0/21 comment=ALBANIA list=CountryIPBlocks
add address=37.139.112.0/21 comment=ALBANIA list=CountryIPBlocks
add action=accept chain=forward comment="Reglas BASICAS" connection-state=\
established,related
add action=accept chain=input connection-state=established,related
add action=drop chain=input connection-state=invalid
add action=accept chain=output connection-state=established,related
add action=drop chain=output connection-state=invalid
add action=accept chain=input comment="PUERTOS VPN" in-interface-list=\
"WAN Interface List" protocol=udp src-port=500,1701,4500
add action=accept chain=input in-interface-list="WAN Interface List" \
protocol=ipsec-esp
add action=drop chain=input comment="Bloquea Trafico Entrante" \
add action=netmap chain=dstnat disabled=yes dst-address=192.168.0.0/24 \
to-addresses=192.168.4.10
add action=masquerade chain=srcnat out-interface=l2tp-VPN
add disabled=no distance=1 dst-address=192.168.0.0/24 gateway=10.10.10.1 \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.10.10.1 pref-src=\
"" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.0.0/24,192.168.4.0/24 port=1985
set api-ssl disabled=yes
/routing rule
add action=lookup-only-in-table disabled=no src-address=10.10.10.1/32 table=\
main
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name=MMCG
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
