I don't get it...
Why does the "L009UiGS-2HaxD-IN" router only come with 2.4GHz wireless? Why not 5GHz as well?
Any thoughts on this matter?
I was hoping for some considerations as to why not include dual-band WiFi.What opinion do you expect?
Isn't that what the "RB5009UPr+S+IN" offers?I would go for an even tougher question, why does it have Wi-Fi at all?
Try putting 4 of them (and their big ears) in 1 1U rack space.
The RM version is fine (limited in power but fine) for some uses, but the HaxD-IN?
Not sure to understand.Isn't that what the "RB5009UPr+S+IN" offers?
Actually there are 2 form factors for RB5009 (and L009 took its case from RB5009, that latter one was released first long before there was even mentioning of L009).The RB009 is a much more powerful device that comes in the same form factor of the L009 (4 can be mounted in i1U) in two models, both without radios, one with and one without PoE out.
You can, but you shouldn't just because you can.L009UiGS-2HaxD-IN
L009 is more than just a router. This product line is up to 4 times faster than RB2011, it has a modern ARM CPU with container support, an innovative enclosure that allows mounting up to four routers in a single 1U space, more RAM, PoE, and 2.5G SFP support. This version comes with 2.4 GHz ax dual-chain wireless.
The earlier reply from MikroTik has been that the L009 is intended solely as the replacement for their most successful device ever, the RB2011.
Apparently there are still people buying that, and they wanted to introduce a replacement device with similar price and features.
When you require 5GHz, don't buy the L009 but select another device.
.... makes no sense. It's silly to not have put 5ghz inThe earlier reply from MikroTik has been that the L009 is intended solely as the replacement for their most successful device ever, the RB2011.
Sure, but there's a big difference between not trying to satisfy everybody, and releasing total gimp....No way to satisfy all.
No, they are buying it because it costs ~$120 and has a lot of features..... makes no sense. It's silly to not have put 5ghz inThe earlier reply from MikroTik has been that the L009 is intended solely as the replacement for their most successful device ever, the RB2011.
I'm pretty sure people aren't buying the 2011 specifically because it DOESNT have 5ghz in it
Whatever you do, do not buy that one!Still: no way to satisfy all
There is 4011iGS+5HacQ2HnD-IN if you need both freq ...
It is very simple. Everywhere where is 5GHz there are only 2dBi 2,4GHz antennas. L009 has a 4dBi 2,4GHz antennas, meaning you can have a signal in the whole house and garden with a single device. If you do not need high-speed wi-fi (e.g. for VR headset).... makes no sense. It's silly to not have put 5ghz inThe earlier reply from MikroTik has been that the L009 is intended solely as the replacement for their most successful device ever, the RB2011.
Should the L009 have also had half its ports 100mbit just because its a 2011 replacement?
If its a true replacement why only 8 ports and not 10?
Times change, products improve and get better - or at least they should
Whilst its true that plenty of devices are still 2.4ghz and your weather monitor or cheap TV might do just fine, typically it's a mixed environment and not having 5ghz just gimps the laptop/phones that would substantially benefit from it (and further takes away from the 2.4ghz airspace, slowing down the slow devices even further)
