I'm struggling to setup an RB5009 with VLAN. I tried to follow the examples from the manual. Unfortunately, I cannot make it work.
My attempt so far is:
- use the latest firmware
- start from factory settings
- create a management port (ether8)
- create a first VLAN (194) on bridge port ether5, access port
- make the RB5009 reachable on ether5, IPv4 (address 10.126.194.1/24)
- setup DHCP in VLAN
- no dhcp address assignment
- when trying with a manually set IP address, I cannot reach (ping) the RB5009
- wireshark on the client sees:
- STP, CDP traffic from RB5009
- ICMPv6, DHCP, MDNS traffic from the client machine
- RB5009 sees the MAC of the client machine in Bridge > Hosts
Kind regards,
Timo
Code: Select all
# 1970-01-06 20:04:05 by RouterOS 7.13.5
# software id = TFGT-4B36
# model = RB5009UG+S+
# serial number = x
add admin-mac=REDACTED auto-mac=no comment=defconf frame-types=admit-only-vlan-tagged name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan-og-main vlan-id=194
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=mgmt ranges=192.168.89.220-192.168.89.239
add name=og-main ranges=10.126.194.193-10.126.194.254
add address-pool=mgmt interface=ether8 name=mgmt server-address=192.168.88.2
add address-pool=og-main interface=vlan-og-main name=og-main server-address=10.126.194.1
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether5 pvid=194
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add interface=ether8 list=LAN
add interface=vlan-og-main list=LAN
add address=192.168.89.1/24 interface=ether8 network=192.168.89.0
add address=10.126.194.1/24 interface=vlan-og-main network=10.126.194.0
/ip dhcp-client
add address=10.126.194.0/24 dns-server=10.126.194.1 gateway=10.126.194.1 netmask=24
add address=192.168.89.0/24 dns-server=192.168.89.1 gateway=192.168.89.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
