I have a question concerning PPPoE over VLAN, I'm hoping someone could help. Running a CRS125-24G and a CRS328-24P-2S+ connected via both ether1 interface.
Since my ISP allows me to have two public adresses I'm trying to get two PPPoE interface over tagged vlan 35 from the same GPON ONU in my CRS125-24G SFP port. I found a way to make it work by having two seperate bridge but I need to have extra vlan traffic going through ether1, thus requiring untagged traffic to work for vlan1, and tagged traffic vlan id 35.
Here are the bridge configuration on the CRS125
Code: Select all
add admin-mac=CC:2D:E0:99:AF:AD auto-mac=no comment=defconf name=bridge port-cost-mode=short protocol-mode=none vlan-filtering=yes
/interface vlan
add interface=ether1 name=ether1-vlan2 vlan-id=2
add interface=ether1 name=ether1-vlan35 vlan-id=35
add interface=sfp1 name=sfp1-vlan35 vlan-id=35
add interface=bridge name=vlan10-Public vlan-id=10
/interface pppoe-client
add add-default-route=yes disabled=no interface=sfp1-vlan35 name=pppoe-out1 use-peer-dns=yes user=********
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether6 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether7 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether8 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether9 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether10 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether11 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether12 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether13 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether14 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether15 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether16 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether17 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether18 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether19 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether20 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether21 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether22 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether23 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether24 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=sfp1 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=wlan1 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether1 internal-path-cost=10 path-cost=10
/interface bridge vlan
add bridge=bridge tagged=ether1,sfp1 untagged=\ bridge,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,ether15,ether16,ether17,ether18,ether19,ether20,ether21,ether22,ether23,ether24 vlan-ids=1
And for the CRS328
Code: Select all
add admin-mac=78:9A:18:68:59:00 auto-mac=no comment=defconf name=bridge port-cost-mode=short protocol-mode=none vlan-filtering=yes
/interface vlan
add add-default-route=yes disabled=no interface=ether1-vlan35 name=pppoe-out1 use-peer-dns=yes user=**********
add bridge=bridge comment=defconf ingress-filtering=no interface=ether1 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether11 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether12 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether13 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether14 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether15 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether16 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether17 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether18 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether19 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether20 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether21 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether22 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether23 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether24 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus1 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus2 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus3 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus4 internal-path-cost=10 path-cost=10
add bridge=bridge tagged=ether1 vlan-ids=1
I do get communication between vlan1 since running dhcpserver on CRS125 I'm getting an IP in the right subnet vlan1 on CRS328 bridge. I added ip's on both ether1-vlan35 interface 192.168.35.1 on the crs125 and 192.168.35.2 on the crs328, they don't ping each other in this vlan.
Any help would be very appreciated.
Rock.
