Currently, I need an AX router that supports using AP + STA mode simultaneously. I can’t get ISP in my workspace unit, so I need to use the public workspace Wi-Fi. To increase security, I need a Wi-Fi router that can use one band as a Wi-Fi client (WAN) to connect to the workspace Wi-Fi, and another band to act as home Wi-Fi (LAN). The outgoing traffic will be secured by Wireguard (UDP) or OpenVPN (TCP), depending on the application type.
I’ve read some old threads stating that past Mikrotik Wi-Fi 5 products support this usage, but I’m not sure if the modern hAP ax series does. Some say it depends on hardware support.
