Hi!
I have an existing home setup with a single CRS, 3 bridges and CAPsMAN set up with separate DHCPs to segregate 3 different networks. Since my CRS regularly has hickups and the only answer I got was that it's too weak for what I ask of it, i have bought a RB5009 as my main router.
I am now in front of the daunting task of setting up the network, and since I now have 2 devices I have to set up VLANs. Having watched a few videos I am still no closer in how to best set up my devices.
Here is a rough network map:
mermaid diagram link
I am unsure how to connect my cAPs (the AX is not yet existent, but planned. When it arrives Internal will get the additional 6Ghz Wifi)
I probably need to connect them through my CRS326, at least the AX since the RB5009 only has 2.5Ghz ports?
How do I configure the different ports? As far as I understood, on the CRS I need to configure all ports with respective "VLAN tagging"?
Additionally I have another qsfpplus to my PC, currently not connected because my current mainboard doesn't have the necessary PCIE, but the next PC will have qsfpplus1 connected to the PC with 40G, so that needs to go through CRS326 only, without packages routed through the RB5009 which would represent a bottleneck at 10G speed?
Any mikrotik experts that can give me some configuration help or point me to the right videos that cover a situation such as mine? I am typically using the GUI but am not afraid of the terminal.
thanks in advance!
