Hello everyone
at first, I apologize if my post is repetitious, my search for a good result was unsuccessful and also I have not enough time, thank you if there are any links or hints.
suppose my scenario as follows:
I have 2 WAN link:
ether1-WAN1 --> 1.1.1.1 (public IP)
ether2-WAN2 --> 2.2.2.2 (public IP)
I have 1 local network (192.168.70.0/24)
ether3-LAN --> 192.168.70.1
I have 1 Server that is connected to ether3-LAN interface with remote desktop enabled:
Server IP: 192.168.70.20 Server Gateway: 192.168.70.1
what I want to do is:
remote desktop users be enable connect to server with both WAN links ( 1.1.1.1 and 2.2.2.2).
so what is my wrong with following configuration:
/ ip firewall nat
add chain=srcnat out-interface=ether1-WAN1 action=masquerade
add chain=srcnat out-interface=ether2-WAN2 action=masquerade
add action=dst-nat chain=dstnat dst-port=3389 in-interface=ether1-WAN1 protocol=tcp to-addresses=192.168.70.20 to-ports=3389
add action=dst-nat chain=dstnat dst-port=3389 in-interface=ether2-WAN2 protocol=tcp to-addresses=192.168.70.20 to-ports=3389
/ ip firewall mangle
add chain=forward in-interface=ether1-WAN1 action=mark-connection new-connection-mark=ether1-WAN1_conn
add chain=forward in-interface=ether2-WAN2 action=mark-connection new-connection-mark=ether2-WAN2_conn
add chain=forward connection-mark=ether1-WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=forward connection-mark=ether2-WAN2_conn action=mark-routing new-routing-mark=to_WAN2
/ ip route
add dst-address=0.0.0.0/0 gateway=1.1.1.1 distance=1 routing-mark=to_WAN1
add dst-address=0.0.0.0/0 gateway=2.2.2.2 distance=1 routing-mark=to_WAN2
thanks in advance
