Filo
7.14 and SMB on RB5009
Fri Mar 01, 2024 8:36 pm
Hey,
maybe I was too fast with upgrading to 7.14 (recently released).
I saw the changelog regarding SMB and a few posts about in the release thread but I'm unsure if I need to change the settings now.
SMB was working before, now it's not accessible from Windows-Clients.
I do not need to add the "rose-storage" package, since they moved SMB out of this package to the "standard" /IP/SMB-Package in order to update it, am I right?
Anyway it's stuck here - is it for everyone or just my dumbness or is it lacking documentation at the moment?
Thanks for any input and have a great weekend,
Martin
massinia
Re: 7.14 and SMB on RB5009
Fri Mar 01, 2024 8:52 pm
Hi, try to remove old smb credentials from windows also if they are the same and use \\routerIP\shareforder URL format
Filo
Fri Mar 01, 2024 9:17 pm
Did this - sadly no joy. There were stored credentials and mapped drives, removed both and tried to map new.
Behaves like SMB is not active at all on the routerboard ("Network share not found" - in German "Der Netzwerkpfad wurde nicht gefunden").
mukkelek
Wed Mar 06, 2024 6:52 pm
SMB sharing worked for me on 7.13. Formatting too. On 7.14, if I try to connect to the SMB share, there is a kernel failure. Formatting does not work on 7.14, there is a kernel error when formatting FAT32.
h1ghrise
Wed Mar 06, 2024 11:19 pm
my RB5009 just crashes on 7.14 when I try to access SMB share from my MacBook :(
mukkelek
Thu Mar 07, 2024 10:26 am
Same error on AC3 and AX3. There is no error on RB3011....
PaulB
Thu Mar 07, 2024 2:58 pm
Same error on RB750.
gmasip
Sat Mar 09, 2024 7:03 am
Same problems using L009: SMB worked OK with 7.13.5; migrated to 7.14 I get the error "The remote device doesn't accept the connection" from Windows.
The USB unit is there and is recognized by L009: the MINIDLNA server (container) that uses it is still working (fortunately).
Update March 12
7.14.1 does not solve the problem.
krzysztofciupala
Sun Mar 10, 2024 8:32 pm
Same error on RB750Gr3 and RBD52G-5HacD2HnD
mukkelek
Wed Mar 13, 2024 10:42 pm
I updated to 7.14.1. The error is gone.
h1ghrise
Thu Mar 14, 2024 12:10 pm
I raised a ticket to support. its working after disabling encryption on the share (require-encryption=no).
When it's (officially) fixed and confirmed, I'll update.
valnik
Thu Mar 14, 2024 10:40 pm
SMB not working, i have the same error: "The remote device doesn't accept the connection" from Windows /it is also not working from linux/.
EDIT: i simply tried to add DOMAIN and COMMENT in SMB settings..and now is working. Weird...
pOZORjED
Fri Mar 15, 2024 9:52 am
Had to turn SMB off, otherwise my rb4011 was rebooting every few hours.
foegra
Mon Mar 18, 2024 11:23 pm
This is so weird. Running 14.1 - had add comment in SMB settings - then it started to work. Mikrotik AX3.
ShadowWolf
Sun Mar 24, 2024 11:01 pm
Yup, same thing did fix my problem. RBD52G
But listen to this, if you remove the comment, it stops working, and if you type the same comment again it still does not work. You need to type a new comment (different that the previews one) and it works again.
Users browsing this forum: Amazon [Bot], anav, GoogleOther [Bot], jurajhampel, Majestic-12 [Bot], Techsystem and 30 guests
