I have this wierd issue. When I install multicast in RC13 I loose all routes on the system (RB532). Blank page on ip->routes. Not even the directed connected routes.
When I disable or uninstall it the routes reapear so is the normal operation. With mcast installed I cannot pass any traffic anywhere and if I try adding the routes manually (even the directly connected ones they are all in blue and inactive.
One last hint is that I also have installed mpls package. I have not tryed mcast without mpls to see if I have the same issue.
A bug I guess...
