Philippe57
Calculate date and time in script
Mon Mar 04, 2024 7:34 pm
Hello everyone,
I'm trying to calculate an end date with 2 variables:
1 the initial value ($lastSeenStr) which has the format MM/DD/YYYY HH/MM/SS example: mar/04/2024 16:37:18.
and the other variable ($validity) which can have 2 formats: 3d00:00:00 or 01:00:00
I would like to find the end date by adding the variable $lastSeenStr + $validity = $Endvaliditydatetime
Thank you for your help
optio
Long time Member
Long time Member
Re: Calculate date and time in script
Mon Mar 04, 2024 7:54 pm
See script in this post, for converting $lastSeenStr (date-time format) into timestamp you can use $datetime2epoch function created by @rextended taken from here, $validity is in time type, to convert it into timestamp you can use ROS global command :tonum, in your case [:tonum $validity] (if is string variable you can convert it with [:tonum [:totime $validity]]) and then you can sum both timestamps. If you need to convert summed timestamps result back to date-time format you can use also @rextended function $unixtodatetime from here.
Philippe57
Tue Mar 05, 2024 7:01 pm
hello and thank you for your feedback
the first variable is ok but I have a problem with $validity, I can't retrieve a value.
as this value can have the format: 3d00:00:00 or 01:00:00 I would like to have it in the same type of result as the datetime2epoch function in order to calculate it with
thank you again for your help
optio
Long time Member
Long time Member
Tue Mar 05, 2024 7:25 pm
Regarding $validity it is already explained in my previous post, but if is hard to understand, here it is:
>:local validity 3d00:00:00; :put [:tonum $validity]
259200
>:local validity 01:00:00; :put [:tonum $validity]
3600
>:local validity "3d00:00:00"; :put [:tonum [:totime $validity]]
259200
>:local validity "01:00:00"; :put [:tonum [:totime $validity]]
3600
rextended
Tue Mar 05, 2024 11:17 pm
1ft + 1m do not do 2something,
You must first convert ft to m, or m to ft, or both to another omogeneous format.
Since "mar/04/2024 16:37:18" is a stupid string, only an idiot of a programmer (I'm referring to the past) could choose such
a silly method of representing the date, instead of using a better sortable and more matematically logic form, like: 2024-03-04 16:37:18.
(same consideration for the Italian "& Co." 04/03/2024),
Since a string is a string, you must first convert date-time to unix time and interval to seconds, then this is possible:
current_unix_time + time_interval_seconds = next_unix_time
Converting next_unix_time back to one date, you have the wanted value.
For example this print current timestamp value ahead of 1 hour on v7.13.5
:put ([:timestamp] + 1h)
the same, but for out the unix epoch, but this time 3 days
:put [:tonum ([:timestamp] + 3d)]
The function datetime2epoch is explained here
viewtopic.php?p=994849#p994849
And unixtodatetime here
viewtopic.php?p=977170#p977170
Philippe57
Wed Mar 06, 2024 11:03 am
hello and thank you for your feedback, I am trying to integrate it into my script with this code:
        :local validitytime [:tonum $validity];
        :log info "validitytime: $validitytime";
but nothing appears in my logs:
optio
Long time Member
Long time Member
Wed Mar 06, 2024 11:34 am
Is it $validity string type variable then? Did you try
:local validitytime [:tonum [:totime $validity]]
Or could be ROS version issue, you did not specify on which is this performed, maybe on older versions :tonum from time doesn't work.
Philippe57
Wed Mar 06, 2024 11:51 am
here is my current version:
and yes I tried:
        :local validitytime [:tonum [:totime $validity]];
and that doesn't work either
the variable $validity comes from the following code:
        :local validity [/tool user-manager profile limitation get $profileLimit value-name=uptime-limit];
        :log info "validity: $validity";
rextended
Wed Mar 06, 2024 1:51 pm
on v6.x do not work any that is only on v7.x
you can use only my functions on v6
Example of 3 days (259200 seconds) and 1 hour (3600 seconds) ahead mar/04/2024 16:37:18
example code
:global datetime2epoch do={
    :local dtime [:tostr $1]
    /system clock
    :local cyear [get date] ; :if ($cyear ~ "....-..-..") do={:set cyear [:pick $cyear 0 4]} else={:set cyear [:pick $cyear 7 11]}
    :if (([:len $dtime] = 10) or ([:len $dtime] = 11)) do={:set dtime "$dtime 00:00:00"}
    :if ([:len $dtime] = 15) do={:set dtime "$[:pick $dtime 0 6]/$cyear $[:pick $dtime 7 15]"}
    :if ([:len $dtime] = 14) do={:set dtime "$cyear-$[:pick $dtime 0 5] $[:pick $dtime 6 14]"}
    :if ([:len $dtime] =  8) do={:set dtime "$[get date] $dtime"}
    :if ([:tostr $1] = "") do={:set dtime ("$[get date] $[get time]")}
    :local vdate [:pick $dtime 0 [:find $dtime " " -1]]
    :local vtime [:pick $dtime ([:find $dtime " " -1] + 1) [:len $dtime]]
    :local vgmt  [get gmt-offset]; :if ($vgmt > 0x7FFFFFFF) do={:set vgmt ($vgmt - 0x100000000)}
    :if ($vgmt < 0) do={:set vgmt ($vgmt * -1)}
    :local arrm  [:toarray "0,0,31,59,90,120,151,181,212,243,273,304,334"]
    :local vdoff [:toarray "0,4,5,7,8,10"]
    :local MM    [:pick $vdate ($vdoff->2) ($vdoff->3)]
    :local M     [:tonum $MM]
    :if ($vdate ~ ".../../....") do={
        :set vdoff [:toarray "7,11,1,3,4,6"]
        :set M     ([:find "xxanebarprayunulugepctovecANEBARPRAYUNULUGEPCTOVEC" [:pick $vdate ($vdoff->2) ($vdoff->3)] -1] / 2)
        :if ($M>12) do={:set M ($M - 12)}
    :local yyyy  [:pick $vdate ($vdoff->0) ($vdoff->1)] ; :if ((($yyyy - 1968) % 4) = 0) do={:set ($arrm->1) -1; :set ($arrm->2) 30}
    :local totd  ((($yyyy - 1970) * 365) + (($yyyy - 1968) / 4) + ($arrm->$M) + ([:pick $vdate ($vdoff->4) ($vdoff->5)] - 1))
    :return      (((((($totd * 24) + [:pick $vtime 0 2]) * 60) + [:pick $vtime 3 5]) * 60) + [:pick $vtime 6 8] - $vgmt)
:global unixtodatetime do={
    :local ux [:tonum $1]
    :local Fzerofill do={:return [:pick (100 + $1) 1 3]}
    :local prMntDays [:toarray "0,0,31,59,90,120,151,181,212,243,273,304,334"]
    :local vgmt      [:tonum [/system clock get gmt-offset]]; :if ($vgmt > 0x7FFFFFFF) do={:set vgmt ($vgmt - 0x100000000)}
    :local tzepoch   ($ux + $vgmt)
    :if ($tzepoch < 0) do={:set tzepoch 0} ; # unsupported negative unix epoch
    :local yearStart (1970 + ($tzepoch / 31536000))
    :local tmpbissex (($yearStart - 1968) / 4) ; :if ((($yearStart - 1968) % 4) = 0) do={:set ($prMntDays->1) -1 ; :set ($prMntDays->2) 30}
    :local tmpsec    ($tzepoch % 31536000)
    :local tmpdays   (($tmpsec / 86400) - $tmpbissex)
    :if (($tmpsec < (86400 * $tmpbissex)) and ((($yearStart - 1968) % 4) = 0)) do={
        :set tmpbissex ($tmpbissex - 1) ; :set ($prMntDays->1) 0 ; :set ($prMntDays->2) 31 ; :set tmpdays  ($tmpdays + 1)
    :if ($tmpsec < (86400 * $tmpbissex)) do={:set yearStart ($yearStart - 1) ; :set tmpdays   ($tmpdays + 365)}
    :local mnthStart 12 ; :while (($prMntDays->$mnthStart) > $tmpdays) do={:set mnthStart ($mnthStart - 1)}
    :local dayStart  [$Fzerofill (($tmpdays + 1) - ($prMntDays->$mnthStart))]
    :local timeStart (00:00:00 + [:totime ($tmpsec % 86400)])
    :return "$yearStart/$[$Fzerofill $mnthStart]/$[$Fzerofill $dayStart] $timeStart"
:put [$unixtodatetime ([$datetime2epoch "mar/04/2024 16:37:18"] + 259200)]
:put [$unixtodatetime ([$datetime2epoch "mar/04/2024 16:37:18"] +   3600)]
Users browsing this forum: Bing [Bot] and 3 guests
