gducharme
Default Password RB4011 GS+RM
Tue Mar 05, 2024 6:09 am
Can someone confirm if a username of admin and a blank password is the correct default username and password for the RB4011 GS+RM . I cannot access the router via the browser. Winbox sees the router but says the password is incorrect. I have tried to factory reset the router however I have no way to confirm that the reset is actually successfully completing
gigabyte091
Re: Default Password RB4011 GS+RM
Tue Mar 05, 2024 6:32 am
Check sticker on your box, there should be password on it if device is purchased recently. My RB4011 arrived without a password but I bought my about 2 years ago.
TheCat12
Tue Mar 05, 2024 9:37 pm
Username is admin, but Mikrotik started randomizing the password for their newer products like the RB4011, so you must check the sticker in the box, on the router, on the box, wherever there is one. Worst case netinstall or flashfig
Users browsing this forum: Callahan, dioeyandika, JanO and 18 guests
