becs
SwOS Lite version 2.18 released!
Tue Mar 05, 2024 2:02 pm
http://www.mikrotik.com/download
What's new in v2.18:
*) added option to set forced 2.5G for SFP+ ports;
*) css610: added a distinct "Health" menu;
*) css610pi: updated PoE firmware;
*) fixed multicast forwarding after disabling IGMP snooping;
*) fixed SNMP ifSpeed OID reporting in certain cases;
*) ftc11xg: fixed DHCP packet forwarding;
*) limit the number of displayed GUI "Hosts" entries up to 512;
*) improved SwOS Lite web interface stability and responsiveness;
holvoetn
Re: SwOS Lite version 2.18 released!
Tue Mar 05, 2024 2:19 pm
Glad to see there is still development for this version.
How do you set this ?
Never mind, found it. Disable autonegotiation and then you can select.
holvoetn
Tue Mar 05, 2024 4:33 pm
Follow up:
On CSS610 I set an S+RJ10 to forced 2.5Gb, connected to ether1 of AX3 using VLAN trunk.
Link becomes active. So far so good.
On AX3 log files I see it determines speed as being 2.5Gb, which is ok however ...nothing passes (after the facts I can see in log files what happened).
Only when I enable autonegotiation, I can get access via that link.
Am I missing something ?
syadnom
Forum Veteran
Forum Veteran
Tue Mar 05, 2024 4:53 pm
can we please please please get option 82 in swos lite!
bratislav
Wed Mar 06, 2024 11:19 am
Follow up:
You should probably disable Auto Negotiation and fix it at 2.5Gbps on AX3 ether1 too...
holvoetn
Wed Mar 06, 2024 11:55 am
When setting speed fixed on AX3 -> No Link on CSS610, both with auto and no autonegotiation.
Also visible on AX3, ether lights go out for that port.
onnoossendrijver
Wed Mar 06, 2024 12:00 pm
When auto negotiation is disabled you often need a crossover cable. Auto-crossover is often also disabled if auto negotiation is disabled
holvoetn
Wed Mar 06, 2024 12:07 pm
I understand what you say but I don't understand why that would be needed... doesn't make sense from a practical point of view.
Auto MDX is something from the previous century !
Anyhow, SUP-146041 created. Let's see what support says about it.
bratislav
Wed Mar 06, 2024 12:50 pm
Actually I believe onnoossendrijver is correct, modern ethernet controllers use standard IEEE 802.3ab auto negotiation protocol to automatically determine MDI, speed and duplex and for a practical standpoint it makes perfect sense, and once you disable auto negotiation you must use crossover cable...
holvoetn
Thu Mar 07, 2024 9:40 am
Got response from support.
Some info provided both from CSS610 and AX3.
In parallel I ordered some CAT6 cross-convertor plugs.
We'll see ...
holvoetn
Thu Mar 07, 2024 11:27 pm
Final ordeal:
it's (again) S-RJ10 acting up. It can not be controlled to set lower speed.
orfeous
Fri Mar 08, 2024 1:56 pm
[quote=holvoetn post_id=1061562 time=1709846844 user_id=185526]
Final ordeal:
[/quote]
Which revision of S-RJ10 are you using? There is a Rev 2
Read about it
holvoetn
Fri Mar 08, 2024 1:58 pm
It is Rev 2.
That module will adjust on its own to lower speed when needed (e.g. when connected to 2.5G port of AX3) but it can not be configured to do so (e.g. when connecting 2 S-RJ10 to each other and not wanting full 10G because it will burn your fingers).
orfeous
Fri Mar 08, 2024 2:53 pm
Yeah they get really hot.
I've read that they need to be set at a fixed speed.
Can you try this on RouterOS also if you have CRS somewhere?
marekm
Fri Mar 08, 2024 4:45 pm
Good to see more development, I'm running a few Netpower Lite 7R devices currently at 2.17.
Please consider feature requests for new releases:
- option to not save all config changes immediately, instead keep them only in RAM, and have a separate "Save" button (this way previous working config can be restored by reboot/power-cycle if you lost access due to wrong change)
- option to reboot (optionally including power-cycling the PoE powered device) after some number of failures to get IP address by DHCP, to recover from wrong config change or hung uplink radio without power-cycle (tricky to do with reverse-PoE redundant power from multiple customers)
gotsprings
Mon Mar 11, 2024 10:25 pm
If I go to the hosts screen... after about 20 seconds I get this at the top of the screen.
ERROR: SyntaxError: Unexpected token '{'
Hominidae
Tue Mar 19, 2024 12:51 am
yup, same here on two css610
holvoetn
Tue Mar 19, 2024 8:42 am
I'm not seeing that.
Edge as browser on Win11.
AndiiiHD
Tue Mar 19, 2024 9:01 am
Confirmed on CSS610:
holvoetn
Tue Mar 19, 2024 9:09 am
O..K ...it took a LOT longer then 20 seconds (just left the window open while I was doing something else).
Now I see it as well.
bratislav
Tue Mar 19, 2024 11:37 am
It is always a good practice to refresh the page to avoid these kind of errors...
robert555
Tue Mar 19, 2024 5:27 pm
Help, I can consult in this forum, I only get a reply and when I reply I get
gotsprings
Tue Mar 26, 2024 1:15 pm
I was about to update a CSS610-8P. When I go to update it doesn't show the 2.18 firmware.
Did something change or get taken down?
https://cdn.mikrotik.com/swoslite/css61 ... i-2.18.bin
Gives me a 503 error
EDIT
Went back to the Switch and Hit Upgrade and it found the upgrade and installed it.
For some reason Chrome won't load the page now... but I need to look into that some more.
marekm
Thu Mar 28, 2024 4:15 pm
I can confirm the syntax error in the Hosts tab after upgrade to 2.18. Fresh Netpower Lite 7R device (default config) upgraded from factory 2.13 firmware. Tried two different browsers (Firefox and Supermium), I've never seen this error in 2.17 or older. Refreshing the page doesn't change anything, and actually Supermium shows the error when freshly started accessing the upgraded device (it was upgraded using Firefox) for the first time.
EDIT: Downgraded to 2.17 - https://cdn.mikrotik.com/swoslite/css61 ... 0-2.17.bin - link edited from 2.18 (fortunately it works, as I haven't seen a "download archive" web page for SwOS/Lite, only for RouterOS). Hosts table displayed just fine, no more syntax errors in both browsers.
darthgizm0
Fri Apr 19, 2024 5:46 am
I upgraded from 2.17 to 2.18 and I receive the error on the Hosts page: ERROR: SyntaxError: missing ) in parenthetical
I have the CSS610-8P and CSS610-8G models.
gotsprings
Tue Apr 23, 2024 4:24 pm
Also... I have ICMP ping set up in netwatch to the CSS610-8P.
Every once in a while it will miss more than 2 of the 5 pings. I get an error note on the router as that's where netwatch is running, which is directly connected to the switch.
But since CSS has no logs... I can't track that.
I have 4 CSS610-8P out there at this point. They all do this.
marekm
Fri Apr 26, 2024 10:10 pm
Are the missing pings new with 2.18, and fixed by downgrade to 2.17? (warning: can't downgrade lower than 2.17 without losing config because of changed config file format - sadly still not hashing the login password, so let's hope for another incompatible change soon).
Over a month has passed and still no fix to that 2.18 syntax error bug? Makes hosts table useless. I'm running 2.17 and waiting for a fix.
marekm
Tue Aug 06, 2024 9:23 pm
A few months have passed - any news about a new bugfix release of SwOS Lite?
I'm still running 2.17 everywhere because of the syntax errors in the hosts table on 2.18.
Has the SwOS Lite development been outsourced, or has the last employee working on it already left?
Put the source on github already :)
Most of the value is in the hardware anyway, few companies make outdoor reverse-PoE switches.
Some new features would be nice but I'm losing hope if even a simple bugfix takes so long.
One that would have saved me a lot of trouble more than once - PoE watchdog (power-cycle the powered device if the switch can't get DHCP for too long, with configurable timeout - like 15 minutes or so, to avoid rebooting during OS upgrades).
It's quite a challenge to ask a few customers to power-cycle their PoE adapters exactly at the same time (so there is a moment when all are off - only then will the switch reboot, because of redundancy - even though not the switch itself was hung, but the powered Cube radio).
marekm
Fri Aug 30, 2024 1:25 am
#[SUP-161444] reported 2024-08-06 - still no response
infabo
Fri Aug 30, 2024 1:39 pm
Your device is a dumb power consuming nothing without SwOS. So don't talk BS. And Mikrotik won't open source SwOS anyways. It wouldn't help you either way, as bugs are not fixed by just the action of publishing the source code.
PS:
Reply in your support ticket directly. Ask for acknowledgement at least. Publishing SUP numbers on the community forum has no effect.
marekm
Fri Aug 30, 2024 6:03 pm
Without SwOS it would probably be an unmanaged reverse-PoE switch (assuming the switch chip has some sane power-up defaults), limited (no VLANs etc.) but still somewhat useful. Before the netpower lite 7R there were chinese reverse-PoE switch boards but I coulnd't find them nicely packaged in an outdoor case which is what MT did and I appreciate it, so I don't have to roll my own ugly outdoor boxes anymore. If source was published with change history, it would be possible to find the specific commit that broke the Hosts table and revert just that, while keeping other changes that fix bugs or add new features. I'm also pretty sure the community would help with more bug fixes and new features. Hey, no password hashing in 2024 - even if using the old Unix V7 crypt() it would be better than nothing. I wouldn't be asking for the source if it was properly maintained, but it doesn't seem to be. New release is made that introduces an obvious easily reproducible bug (which shouldn't have passed the QA if there was any), and no fix in a few months. All I got from the report to support@ was the auto-ack with the SUP number, but no follow-up from any live person - not even the usual "we are working on it, but can't give any ETA".
Users browsing this forum: No registered users and 10 guests
