I've been running a Mikrotik HEX rb750gr3 as my primary router for many years without any issues on my 50/50Mbps Fibre line - I'm not exactly sure what transpired but now when I connect to my ISP via PPPoE, the performance is terrible. There seems to be a definite delay/latency issue, download is fine at 50Mbps but the upload is basically non existent.
If I plug in a cheap TP-Link router, I get full 50/50 with no issues, plug in the Mikrotik, same issue occurs.
I borrowed a Mikrotik HAP AC3 from a friend - same issue. I then went ahead and purchased a new Mikrotik HAP AX3 and the exact same issue occurs.
This leads me to believe that I'm sitting with a config issue (I've tested all network cables/tried various factory made ones so I can rule this out as an issue).
Setup: Fibre ONT -> Mikrotik Eth1
Here's a print of my current config:
Code: Select all
[admin@MikroTik] > export compact hide-sensitive
# 2024-03-05 15:29:25 by RouterOS 7.14
# software id = **ELIDED**
# model = RB750Gr3
# serial number = **ELIDED**
add admin-mac=**ELIDED** auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 use-peer-dns=yes user=\
xxxxx0@telkomsa.net
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
set udp-timeout=10s
/interface detect-internet
set detect-interface-list=all
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=\
127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
established,related hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" \
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=\
!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none \
out-interface-list=WAN
# no interface
add action=masquerade chain=srcnat out-interface=pppoe-out1
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 \
protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=\
in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" \
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=\
icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=\
in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" \
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
