I recently migrated my hexS to an RB5009 and im quite happy with it.
Now, the next step is to migrate my Home Assistant instance + AdGuard Container from my Lenovo M900 to the RB5009.
AdGuard and MQTT is already running fine on the RB5009 and an attached 1TB SSD.
Now, I want to migrate HomeAssistant, which is currently running as HASSOS (HomeAssistant and Addons (which are docker containers running inside of HA)) VM on the M900.
I need the following containers:
- HomeAssistant
- MariaDB (to move away from Sqlite DB as im running quite a few devices, which have caused already some db corruptions during backups)
My questions are:
- Can I run Maria DB as a container from the RB5009?
- Each container needs a veth interface. I don't want to have dozens of IPs taken up by the containers, when they provide only a single Service.. Is DSTNAT the only option here?
- Any idea on how to backup config from HA? (I found https://hub.docker.com/r/linuxserver/duplicati this as an option)
- Is this a feasible approach to run that many containers (especially HA + Maria DB) on a 2GB RAM device?
I would like to have some opinions from you guys, before migrating the important stuff.
Much appreciated.
