Hello all,
I’m trying to connect the CRS310 to a HP-Switch. HP-Port is trunk with tagged vlan’s and all sfp ports on the CRS310 should also be trunk ports with tagged vlan's to connect some other switches.
Initially the CRS310 is in bridge mode with a bridge called "bridge". All ports are connected to "bridge". Management is via "ether1" which is also a port on "bridge".
I want to do this:
add name=bridge1 vlan-filtering=no
add bridge=bridge1 interface=sfp1
add bridge=bridge1 interface=sfp2
etc...
/interface bridge vlan
add bridge=bridge1 tagged=sfp1 vlan-ids=1,9,20,50,51,52,53,60,110
add bridge=bridge1 tagged=sfp2 vlan-ids=1,9,20,50,51,52,53,60,110
etc...
/interface bridge set bridge1 vlan-filtering=yes
But on this step:
/interface bridge port add bridge=bridge1 interface=sfp1
I get "failure: device already added as bridge port" which is logical because interface sfp1 is used by "bridge".
When I change the "sfp1" port to the new created "bridge1" via the GUI the CRS310 says good bye and I can't access it anymore.
Is my first error that I'm trying to do this while the CRS310 is in Bridge-Mode?
I don't want to run the CRS310 in Router-Mode, because I expected to use the CRS310 as a switch.
Thanks for any help
