orfeous
SwOS Lite DHCP server Options
Fri Mar 08, 2024 2:04 pm
For CSS and CRS switches, do they support DHPC Option 66 and 67 to be used for booting via PXE on a server? Defining the switch as DHCP server with those options.
Instead of using DHCP Server on the server. I thought that it might be better to use it on the switch? With VLANs etc..
Do SwOS Lite support those DHCP server options?
I think RouterOS does?
mkx
Re: SwOS Lite DHCP server Options
Fri Mar 08, 2024 5:33 pm
DHCP is L3 (or L5, depends on how you view it) function while SwOS only supports L2.
orfeous
Fri Mar 08, 2024 5:38 pm
SwOS Lite or SwOS or both? I guess the CSS is a no go then..
I will stick to the CRS310
mkx
Sat Mar 09, 2024 11:34 am
Any SwOS.
Users browsing this forum: No registered users and 0 guests
