Yes it is possible.
Ideally use Winbox, or webfig to configure the router.
Non optimal solution, (but likely near enough)
Summary
Add a new 2 port bridge for Wan connection, create and connect a pppoe client to it.
Roughly what I would do:
Starting from the Mikrotik default configuration with a recent version of RouterOS.
Optional
Quickset: Set up a new LAN IP address and DHCP server configuration (only)
Note
Quickset is often flaky, this function usually works, will need to
disconnect ethernet cable from laptop briefly after applying change to
acquire new IP Address.
Setup
- Wifi: Disable Wifi interfaces. (Or configure as required)
- Bridge: Make a second bridge named bridgewan, turn off RSTP on the new bridge.
- Bridge/ Ports: Add ether1 and move ether2 to the bridgewan
- Interfaces: Possibly Add a vlan interface, and attach it to bridgewan (if pppoe needs to be on a VLAN)
- PPPoE: Attach a new pppoe client to either bridgewan, or the vlan interface.
- IP/ DHCP Client: Disable the default IP DHCP Client.
- Interfaces/ Interface List: Add the bridge and pppoe interface and vlan interface (if used) as members of the WAN interface list.
- Ensure the new bridge has hardware offload enabled and running on it.
(Likely by turning off HW offload on each bridge port on original bridge)
Connect ether1 to the ONT
Connect ether2 to the Unifi
ether3 and ether4 are the Hap's Lan interfaces.
Optimisations
Turn off unused services. IP Services:
Maybe turn off sip nat helper. IP/ Firewall/ Service Ports:
If you remove one of the other ports (ether3, ether4) from the original bridge and use it
as a management interface or if little traffic will flow between Lan ports ether3 and ether4
no further optimisation is required.
Otherwise, at a later time you can study the bridge vlan filtering
documentation and create a single vlan filtering bridge with all ports
hardware offloaded.
Edit: Updated Interfaces/ Interface List: Add the bridge,
