The logic is simple. FastTrack is only applied to already established and related connections, this is the default rule out of the box. All other connections are not fast-tracked by definition. Particularly, the new connections will go through the firewall and will get the chance to be packet-marked by the mangle rule. I modified the FastTrack rule to match only packets with no packet marks ("no-mark"). So, the subsequent packets from this connection will bypass FastTrack and continue to go through the firewall, including the mangle rules, continuing to mark packets - which otherwise would not happen due to FT.
Because I'm working with packet marks rather than connection marks (need that since queue trees only work with packet marks), I needed to take care of both directions, hence two mangle rules.
Code: Select all
add action=fasttrack-connection chain=forward comment="fasttrack for established,related" connection-state=established,related hw-offload=yes packet-mark=no-mark
/ip firewall mangle
add action=mark-packet chain=forward in-interface=vlan101 new-packet-mark=intervlan out-interface=vlan102 passthrough=yes
add action=mark-packet chain=forward in-interface=vlan102 new-packet-mark=intervlan out-interface=vlan101 passthrough=yes
