Wed Mar 13, 2024 4:22 am
Thats a downgrade..... going from a multi-core TILE with amazing throughput of 12gigs, which also easily handles your cumulative 7gigs of throughput.
So you have to be clear on the reason for upgrade??
Must be due to the lack of 2.5,5,10 or more gig ports available........................
One move you can make is getting the 2114 model which has about 17 gigs of throughput, and four SPF+ ports.
Its more expensive than the 2004, but still way cheaper than the flagship 2216
Keep in mind the 2004 will max out at around 4.8gigs, so not capable of optimizing one of your WAN connections let alone both concurrently.
If you absolutely need more throughput on ports then get the 2116 and also purchase a CRS317 with 12 sfp+ ports, or the CRS326 if you need more.........
