ringrring
port forwarding problem
Thu Mar 14, 2024 5:06 pm
I have a RB5009 router connected diectly to my fibre modem. I have two security cameras connected to the router at 192.168.88.253 and 192.168.88.254. I would like to view them when not at home.
I have followed this advice to setup the NAT rule for one of the cameras, - https://help.mikrotik.com/docs/display/ ... forwarding
When I check these ports with https://portchecker.co/check-it , they are reported closed.
My computer firewall is turned off at the moment.
Do I need to do anything else in the router to open up the ports ? or am I doing this wrong ?
anav
Re: port forwarding problem
Thu Mar 14, 2024 7:48 pm
No idea without seeing the config.
ringrring
Thu Mar 14, 2024 9:02 pm
# 2024-03-14 18:59:05 by RouterOS 7.14.1
# software id = AKH6-QXXQ
# model = RB5009UPr+S+
# serial number = HDA08BKAFKG
add admin-mac=18:FD:74:CC:AD:C5 auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=------------------------------
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether6 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether7 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether8 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=sfp-sfpplus1 internal-path-cost=\
10 path-cost=10
set udp-timeout=10s
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat comment="front camera" disabled=yes \
dst-address=xx.xxx.xxx.xxx protocol=tcp src-address=0.0.0.0 src-port=8001 \
to-addresses=192.168.88.254 to-ports=8001
add action=dst-nat chain=dstnat disabled=yes dst-address=xx:xx:xx:xx\
dst-port=8001 protocol=tcp to-addresses=192.168.88.254 to-ports=8001
add action=dst-nat chain=dstnat dst-port=8001 in-interface-list=WAN \
log-prefix=192.168.88.254 protocol=tcp src-address=xx:xx:xx:xx to-ports=\
8001
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/London
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
anav
Thu Mar 14, 2024 9:15 pm
(1) slight mod to dns..
set allow-remote-requests=yes servers=1.1.1.1
REMOVE the following default..........
/ip dns static
(2) Take this default rule and create three new rules......... Clearer and better security.
add action=accept chain=forward comment="internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="port forwarding" connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
Nothing so far that I see stopping your required traffic.......... above are improvements.
(3) Okay lets look at your dstnat rule.
DO NOT USE source address 0.0.0.0 USE DST PORT not src port......
If you want to limit which public IPs can access your Server, then create a firewall address list etc........
Note adding a source IP or src address list of IPs also has the side benefit of causing your ports not to be visible on a scan vice just closed.
If your WANIP is dynamic then use in-interface-list=WAN
If your WANIP is static then use dst-address=X>X>X>X { your static WANIP }
To ports not required if same as dst-ports.
ex.
add action=dst-nat chain=dstnat comment="front camera" disabled=no \
in-interface-list=WAN dst-port=8001 protocol=tcp to-addresses=192.168.88.254
Q. Do you have users on the same LAN as the server accessing the server by DYNDNS name/URL ??
ringrring
Thu Mar 14, 2024 10:43 pm
Great, learning a lot.
How do I make those changes, using webfig or command line ?. I would like to see the cameras on the intranet so yes, - do I need to make a masqerade rule?.
anav
Thu Mar 14, 2024 11:26 pm
I use winbox, but webconfig should suffice. You already have a masquerade rule.
ringrring
Fri Mar 15, 2024 12:20 am
so theres not really anything preventing port 8001 being open in my config?.
anav
Fri Mar 15, 2024 4:16 am
Best to clean up the config and if still having issue post the latest config............
k6ccc
Sat Mar 16, 2024 2:17 am
Please note when you post the config, please include your config in a code block. The code block is the 7th icon on the row of icons above the text entry box. It looks like a square with a blob in the middle. When your press that, it will produce a beginning and ending code block. Past your config text between the two blocks.
anav
Sat Mar 16, 2024 3:51 am
Isnt the first non code block config and wont be the last........... you can thank Normis for ensuring the resulting the first posting experience of new users and those supporting them :-)
ringrring
Tue Apr 09, 2024 9:37 am
thanks
ringrring
Thu Apr 11, 2024 10:11 am
I am still struggling with port forwarding my security cameras. I have the config below. When I try to connect from the WAN using my phone I can see packets going up on the connections in routerOS but no transfer of data. Please can someone look at my config. ( I did try set up back to home but then deleted it, because it seemed to slow my home connection speed).
# 2024-04-11 07:40:44 by RouterOS 7.14.2
# serial number = HDA08DKAFKG
add admin-mac=18:BD:74:CC:AD:C5 auto-mac=no comment=defconf name=bridge \
    use-peer-dns=yes user=xxxxxx
    path-cost=10
    path-cost=10
    path-cost=10
    path-cost=10
    path-cost=10
    path-cost=10
    path-cost=10
    10 path-cost=10
set udp-timeout=10s
/interface detect-internet
set detect-interface-list=all
/interface wireguard peers
add allowed-address=xxxxxxxxxxx/32 comment="xxxxxxxxxxx (iPhone16,2)" \
    interface=*D public-key="xxxxxxxx="
    192.168.88.0
/ip cloud
set back-to-home-vpn=enabled ddns-enabled=yes ddns-update-interval=10m
    192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8 verify-doh-cert=yes
/ip dns static
add address=45.90.28.0 disabled=yes name=dns.nextdns.io
add address=45.90.30.0 disabled=yes name=dns.nextdns.io
add address=2a07:a8c0:: disabled=yes name=dns.nextdns.io type=AAAA
add address=2a07:a8c1:: disabled=yes name=dns.nextdns.io type=AAAA
add address=45.90.28.0 name=dns.nextdns.io
add address=45.90.30.0 name=dns.nextdns.io
add address=2a07:a8c0:: name=dns.nextdns.io type=AAAA
add address=2a07:a8c1:: name=dns.nextdns.io type=AAAA
    invalid
add action=dst-nat chain=dstnat comment=front dst-port=8001 \
    in-interface-list=WAN protocol=tcp to-addresses=192.168.88.253 to-ports=\
    8001
add action=dst-nat chain=dstnat comment=back dst-port=8002 in-interface-list=\
    WAN protocol=tcp to-addresses=192.168.88.254 to-ports=8002
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/system note
/system script
add comment=20240401 dont-require-permissions=no name="add dns ip_nextdns" \
    owner=capnahab policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/\
    ip dns static add name=dns.nextdns.io address=45.90.28.0 type=A;\
    \n/ip dns static add name=dns.nextdns.io address=45.90.30.0 type=A;\
    \n/ip dns static add name=dns.nextdns.io address=2a07:a8c0:: type=AAAA;\
    \n/ip dns static add name=dns.nextdns.io address=2a07:a8c1:: type=AAAA;"
add comment="add nat (nextdns)" dont-require-permissions=yes name=nat_nextdns \
    ip firewall nat add chain=dstnat action=redirect protocol=tcp dst-port=53 \
    \n/ip firewall nat add chain=dstnat action=redirect protocol=udp dst-port=\
    53 "
/tool mac-server
mkx
Thu Apr 11, 2024 2:55 pm
Are you sure that cameras provide their service on ports 8001 and 8002? I'd guess they are actually using standard port 80 ... in which case NAT rules should have "to-ports=80" set.
llamajaja
Thu Apr 11, 2024 4:42 pm
(1) recommend change this rule:
TO:
add action=drop chain=forward comment="Drop all else"
(2) As MKX very sideways alluded, there appears to be nothing intrinsically wrong with the config to prevent your desired traffic. Hence his query on confirming correct port allocation.
It would seem you probably are attempting port translation, so the dst-port = PORT HITTING THE ROUTER, to-port = PORT REACHING THE SERVER. The router does the switcheroo for you.
(3) If not using IPV6, ensure its disabled.........
ringrring
Thu Apr 11, 2024 6:17 pm
I have mainly used the default firewall rules. there is an entry
(see config above)
That seems like it may be blocking requests to the camera - what dyou think ?
The ports 8001 (camera 1) and 8002 (camera 2) are what are recommended in the camera instructions and setup in the camera config (as well as port 80). I spose I could try port 80 too but maybe slightly less secure.
ringrring
Thu Apr 11, 2024 6:31 pm
Sorry, I am very much learning here, - I am not sure what you mean, using winbox or webfig how do I do the below ?
gigabyte091
Thu Apr 11, 2024 8:46 pm
Did you make the changes to your firewall rules as @anav suggested you earlier in the topic and later mentioned again by @llamajaja?
Can you confirm that cameras are using only those ports ? What camera brand are you using ?
ringrring
Thu Apr 11, 2024 11:24 pm
I think I have made all the changes, thats why I showed the config.
I am only using those ports.
I don't understand what @llamajaja means by
The cameras are Mobotix M16.
I had this working after @anav's advice. The only thing I did in the interim was try to install back to home from my phone but it seemed to slow my connection down on the LAN so I tried to remove it.
ringrring
Fri Apr 12, 2024 7:30 am
It is now working,
as @anav said 'DO NOT USE source address 0.0.0.0USE DST PORT not src port ' did it.
Now I just need to work out how to make it avaialble from LAN as @anav said
ringrring
Fri Apr 12, 2024 7:21 pm
I would like to be able to view my cameras from the LAN. Here is my NAT config. Neither camera work when viewed from the LAN but are fine from the WAN, - I tried the port number in the second one to see if it made a difference but no.
add action=dst-nat chain=dstnat comment=front dst-port=8001 in-interface-list=WAN protocol=tcp to-addresses=192.168.88.254 to-ports=8001
add action=dst-nat chain=dstnat comment=back dst-port=8002 in-interface-list=WAN protocol=tcp to-addresses=192.168.88.253 to-ports=8002
add action=masquerade chain=srcnat dst-address=192.168.88.254 protocol=tcp src-address=192.168.88.0/24
add action=masquerade chain=srcnat dst-address=192.168.88.253 protocol=tcp src-address=192.168.88.0/24 to-ports=8002
anav
Re: port forwarding problem  [SOLVED]
Fri Apr 12, 2024 8:21 pm
Well if you try to access the camera via the LANIP address of the camera it should work fine.
If you are trying to use the same DYNDNS URL there could be problems.
If users are in the same LAN as the Server then it will not work without modifications. Easiest is to move users or server to different vlan.
If you elect not to do that then you need to address a hairpin nat scenario.
HAIRPIN NAT
1. Regardless of type of WAN connection, a single Source NAT rule is required.
add chain=srcnat action=masquerade src-address=192.168.88.0/24 dst-address=192.168.88.0/24
2. For dynamic WANIP, create a firewall list
/ip firewall address-list
add address=dyndnsURL list=MYWAN
{ alternatively you can use your IP cloud option 'mynetname.net' }
YOUR NAT RULES SHOULD LOOK LIKE THIS:
add action=dst-nat chain=dstnat comment=front dst-port=8001 dst-address-list=MYWAN protocol=tcp to-addresses=192.168.88.254 to-ports=8001
add action=dst-nat chain=dstnat comment=back dst-port=8002 dst-address-list=MYWAN protocol=tcp to-addresses=192.168.88.253 to-ports=8002
3. ENSURE you changed the firewall rules I ALREADY recommended.
TO:
ringrring
Fri Apr 12, 2024 9:57 pm
Thanks very much, yes I can see them using the IP addresses. I think I will continue to use that as hairpin is beyond my understanding and will be on the increasing pile of things to pick up later.
Users browsing this forum: AshuGite and 15 guests
