What would you use as AP to serve 200+ users ?
Switch chip/CPU is the same and specs are very similar....
Radio coverage differences ?
Is it possible to do roaming between asus and mikrotik? If yes then maybe you could use both on different channels.Thanks for replies,
Well, actually an hotspot is managing about 300 wifi users on 50mt coverage radius, over two old asus rt ac1200 wifi router (how bad ? they seems don't care about...)
They asked me for replacing Asus with AX devices: since customer is more worried by cost rather than performance , it is enough a hAP-ax3 performs equallly or sligtly better than asus devices, that's my concern.
Obviously the whole system should be revised for proper performances....
As long as all security settings (and SSID) are equal, you should be able.Is it possible to do roaming between asus and mikrotik? If yes then maybe you could use both on different channels.
This is true for hAP ax³ and Asus RT-AC1200. I think, however, it is not for MT and Asus in general.Since this procefure requires coordination between old and new AP, it's usually (always?) constrained to APs from same vendor (in case of MT even same generation).
According this meaning of "roaming", roaming between MT and Asus is not possible.
