So one could /ipv6/firewall/nat/print without-paging and display ALL firewall entries under the nat table, or /ipv6/firewall/nat/print without-paging stats and display firewall stats for ALL chains under nat.Code: Select allappend detail file follow-only from proplist static where count-only dynamic follow follow-strict interval show-ids stats without-paging
However in /ipv6/firewall/filter/print, the options available are:
It is NO LONGER possible to /ipv6/firewall/filter/print without-paging and display ALL firewall entries under the filter table, nor /ipv6/firewall/filter/print without-paging stats and display firewall stats for ALL chains under filter.Code: Select allforward input output chain file from interval proplist where
I'm guessing this is another bug that seems to have been overlooked. No such problems under /ip/firewall/filter/print, all options are present.
