Is this a bug? Suddenly signal level for 5ghz interface (cap-wifi3) shows positive numbers in column "signal"? Not only in Winbox, verified on CLI too.
CAPsMAN + ROS 7.13.5 + wifi-qcom-ac
Maybe Mikrotik is using some new technology, as a comparison heat pumps go 300% or even 400% efficiency, but they are actually cheating, subtracting heat from the outside environment, you should ask your neighbours how is their wi-fi working.
