Wed Mar 20, 2024 2:27 pm
I split the topic because what you wrote was what's in this thread's title, "hap ax" not "cap ax". (I copy-pasted it without change.) I therefore considered it a distinct topic, not "the same problem" as is often claimed.
Instead of bumping that topic again without adding any new information, try all of the solutions given up-thread and report the results of your attempts so that others can help you with information specific to your situation. You should not assume that you have the "same problem" as someone else merely based on the thread title. You might well have the same symptom but a different cause.
