paula
MASTER INTERFACE UNKNOWN
Wed Mar 20, 2024 4:32 pm
I have a hap ax lite l41g-2axd then I reset it. I netinstalled the main package of arm RouterOS v7 7.14.1 but then the master interface was unknown. Whenever I enable the wifi-qcom in the packages and reboot it, the wireless will be disabled, and vice versa. Whenever I enable the wireless, the wifi-qcom will be displayed, but the master interface is still unknown.
mkx
Re: MASTER INTERFACE UNKNOWN
Wed Mar 20, 2024 8:59 pm
Forget about "wireless" package on ax devices (hAP ax lite is one of them). You need wifi-qcom package. And then configure things under /interface/wifi.
More about wifi/wireless in 7.13 and later: viewtopic.php?t=202578
paula
Fri Mar 22, 2024 6:23 am
can you teach me the step on how to configure or connect it to a wifi without the wireless package?
paula
Fri Mar 22, 2024 6:24 am
mkx
Fri Mar 22, 2024 7:53 am
As the linked article says: on your device, you need basic routeros installed and optional package named "wifi-qcom". After you get these packages installed, I suggest you to reset router to factory default config. The rest of configuration is done in /interface/wifi (I believe that's WiFi main menu in WebFig). Documentation is here.
Users browsing this forum: Amazon [Bot], Google [Bot] and 16 guests
