Code: Select all
0 As ;;; WAN1
dst-address=0.0.0.0/0 routing-table=main pref-src="" gateway=XX.XX.XX.1 immediate-gw=XX.XX.XX.1%sfp-sfpplus1_WAN distance=1 scope=30
target-scope=10 suppress-hw-offload=no
2 As ;;; WAN2-dns
dst-address=1.0.0.1/32 routing-table=main pref-src="" gateway=XX.XX.XX.158 immediate-gw=XX.XX.XX.158%ether2_WAN2 distance=1 scope=30
3 As ;;; WAN1-dns
dst-address=1.1.1.1/32 routing-table=main pref-src="" gateway=XX.XX.XX.1 immediate-gw=XX.XX.XX.1%sfp-sfpplus1_WAN distance=1 scope=30
4 As ;;; WAN1-21
dst-address=0.0.0.0/0 routing-table=WAN21 pref-src="" gateway=XX.XX.XX.158 immediate-gw=XX.XX.XX.158%ether2_WAN2 distance=1 scope=30
0 ;;; Internet Test - WAN1
host=1.1.1.1 type=icmp up-script=ip route enable [find where comment=WAN1] down-script=ip route disable [find where comment=WAN1] test-script=""
thr-max=2s thr-avg=700ms thr-stdev=700ms thr-jitter=2s http-codes="" status=up
1 ;;; Internet Test - WAN2
host=1.0.0.1 type=icmp up-script=/ip route enable [find where comment=WAN1-21]\r\n down-script=/ip route disable [find where comment=WAN1-21]\r\n
test-script="" thr-max=2s thr-avg=700ms thr-stdev=500ms thr-jitter=2s http-codes="" status=up
