HeA9
hAP AX2 WireGuard Throughput (UDP)
Mon Mar 25, 2024 12:15 am
Hello!
Anyone kind enough to give me an estimate of the WireGuard throughout for an hAP AX2? I’ve search the web but cannot find anything useful.
Thanks in advance
gigabyte091
Re: hAP AX2 WireGuard Throughput (UDP)
Mon Mar 25, 2024 3:36 pm
Don't know but can measure tomorrow, for hAP ac2 i get about 363Mbps DL/ 341 Mbps UL
HeA9
Mon Mar 25, 2024 4:26 pm
Thanks! How are you measuring it? I’m getting 150-200 using the bandwidth test from another mikrotik device.
Thanks!
holvoetn
Mon Mar 25, 2024 4:53 pm
When testing: test THROUGH the device, not USING the device.
If you do bandwidth test AND wireguard encryption on the same device, your cpu might not like it that much...
Best to use Iperf on PC - cable - Tik -Wireguard- Tik - PC with Iperf.
gigabyte091
Mon Mar 25, 2024 6:52 pm
I'm using Openspeedtest.
Server is on one W11 machine connected to CHR (special PC running proxmox and all network interfaces are passed directly to the CHR)
CHR connected to my switch on main network.
Test device connected to the same switch and same VLAN as CHR.
And then on test device any client that can open openspeedtest in browser.
All test devices are running default config with few extra fw rules to allow wg to work.
gigabyte091
Tue Mar 26, 2024 7:35 am
Test results for ax2:
Download: 644.3 Mbps (avg CPU usage 81%, cpu1 at 100%)
Upload: 356.2 Mbps (avg CPU usage 74%, cpu1 at 100%)
ROS version: 15beta8 on both devices. And don't use USB network cards for test... I changed 2 TP-Link cards, every time test starts, get up to speed and then you hear disconnect sound in windows :lol:
HeA9
Wed Apr 03, 2024 1:52 pm
Thanks for the advice and the numbers. Why such big difference between upload and download?
Regards!
Users browsing this forum: Semrush [Bot] and 7 guests
