iustin
Memory leak for cap AC 7.14 running wifi-qcom-ac?
Wed Mar 27, 2024 7:57 pm
I've seen this now a couple of times, both with 7.14 and 7.14.1:
Basically reboot the cap AC, and watch its memory slowly but inexorably go down. Once it's above ~87% usage, the cap AC becomes unresponsive (time out waiting for process 85/24/etc), and I have to hard power cycle.
The interesting thing is that I have two of these, connected to same capsMAN, and only one does this for a while, then the problem moves to the other, etc.
Did anyone else see this? Is it a known issue? (Should I just move to cap AX with its 1GB of RAM?)
infabo
Re: Memory leak for cap AC 7.14 running wifi-qcom-ac?
Wed Mar 27, 2024 8:00 pm
7.13.5, cap ac, wifi-qcom-ac, uptime 1week. free memory: 32.6mb
iustin
Wed Mar 27, 2024 11:00 pm
The actual free memory is less concerning than the fact that it continuously decreases between reboots. This is the same graph but over 6 months: you can clearly see that until 7.13 and the new wifi-qcom-ac drivers it was stable, since then it's not really stable - and seems to have gotten worse recently:
I don't know if it's capsman, the number of connected devices, or something else. But it doesn't seem stable at all.
infabo
Wed Mar 27, 2024 11:11 pm
What happened on 12/27?
iustin
Wed Mar 27, 2024 11:23 pm
That's when I upgraded to 7.13, but still using old drivers, if I remember correctly. My upgrade timeline:
- migrated host from hAP ac to cAP ac: 2023.11.22
- 7.12 → 7.13: 2023.12.24
- 7.13 → 7.13.4: 2024.02.08
- 7.13.4 → 7.14.1: 2024.03.24
So it was stable on 7.8 and 7.12, up until 7.13. Since 7.13, it's more or less leaking memory. Either 7.13 itself, or the wifi-qcom-ac drivers.
infabo
Thu Mar 28, 2024 8:24 am
So basically you say, leaking memory since 7.13 and qcom drivers? What's odd, you already had only like 60mb free memory on 7.12 with capac.
iustin
Thu Mar 28, 2024 12:43 pm
Only 60MB free (out of 128MB) is not bad (for me). I'd be happy if I could stay there.
I've now disabled connection tracking entirely, and there was a reduction in memory usage, but the leak is still present. I'll probably file a support ticket, since it doesn't seem to be a widely known issue.
pajapatak
Thu Mar 28, 2024 7:22 pm
I can confirm this behavior, with one hap ac3 and wifi-qcom-ac drivers. Two other hap ac3, with legacy drivers don't show this behavior.
iustin
Thu Mar 28, 2024 7:25 pm
Oh, thanks, this is a good datapoint!
Users browsing this forum: b0207191, kartexa, SensingWrong and 18 guests
