I have tried going over most of the tutorials and still can't seem to figure it out since they are for earlier versions of ros.
This is my config. I have confirmed the vpn is in running status.
I want to route one ip address through the vpn and keep the rest with direct access, if not connected then keep the default connection.
Thanks in advance.
Code: Select all
add admin-mac= auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid="Hap lite" wireless-protocol=802.11
/interface ovpn-client
add certificate=cert_ovpn-import1711582176 cipher=aes128-cbc connect-to=\
us1.freeopenvpn.online disabled=yes mac-address=FE:1F:0B:94:95:61 name=\
freevpn port=443 user=freeopenvpn verify-server-certificate=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/routing table
add disabled=no fib name=vpnroute
add bridge=bridge comment=defconf interface=pwr-line1
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
192.168.1.0
/ip dhcp-client
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=vpnroute \
passthrough=yes src-address=192.168.1.251
# freevpn not ready
add action=masquerade chain=srcnat out-interface=freevpn
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.231.1 \
routing-table=vpnroute suppress-hw-offload=no
/ip upnp
set enabled=yes show-dummy-rule=no
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Africa/Nairobi
/system leds
add interface=wlan1 leds=user-led type=interface-activity
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.google.com
/system scheduler
add comment="Restarting router every day." interval=1h name=Reboot on-event=\
"/system reboot" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=2024-03-28 start-time=09:57:32
/tool mac-server
/tool mac-server mac-winbox
#error exporting "/tool/sms"
