I have a configuration in which I have two subnets in two different vlans, and I want to give different upload priorities to the various subnets and to some services (VoIP etc..) via queue tree. I used mangles to mark connections and packages. I see that the connections are marked perfectly (I see them correct in the connection table
while the packets are not
(the traffic all goes into the no mark queue). Below I report the configuration (cleaned of the sections not related to the topic).
Code: Select all
# 2RouterOS 7.14.1
# model = RBD52G-5HacD2HnD
add ingress-filtering=no name=bridge1 vlan-filtering=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=
/interface vlan
add interface=bridge1 name=vlan-ezio vlan-id=200
add interface=bridge1 name=vlan-ufficio vlan-id=100
add name=WAN
add name=LAN
add name=dhcp_pool0 ranges=192.168.1.100-192.168.1.200
add name=dhcp_pool1 ranges=10.0.0.100-10.0.0.200
add address-pool=dhcp_pool0 interface=vlan-ufficio name=dhcp1
add address-pool=dhcp_pool1 interface=vlan-ezio name=dhcp2
/queue type
add fq-codel-limit=1000 fq-codel-quantum=300 fq-codel-target=12ms kind=fq-codel \
name=fq-codel
/queue tree
add max-limit=30M name="Total Download" parent=bridge1 queue=fq-codel
add name="Other Traffic down" packet-mark=no-mark parent="Total Download" \
queue=fq-codel
add name=HyperBackup packet-mark=hyperbackup_packets parent="Total Download" \
priority=7 queue=fq-codel
add name=Ezio packet-mark=ezio_packets parent="Total Download" priority=6 \
queue=fq-codel
add name=Azienda packet-mark=azienda_packets parent="Total Download" priority=5 \
queue=fq-codel
add name=VoIP packet-mark=VoIP_packets parent="Total Download" priority=1 \
queue=fq-codel
add max-limit=3M name="Total Upload" parent=pppoe-out1 queue=fq-codel
add name=VoIP_Up packet-mark=VoIP_packets parent="Total Upload" priority=1 \
queue=fq-codel
add name=Azienda_Up packet-mark=azienda_packets parent="Total Upload" priority=\
5 queue=fq-codel
add name=Ezio_Up packet-mark=ezio_packets parent="Total Upload" priority=6 \
queue=fq-codel
add name=Hyperbackup_Upload packet-mark=hyperbackup_packets parent=\
"Total Upload" priority=7 queue=fq-codel
add name="Other Traffic Upload" packet-mark=no-mark parent="Total Upload" \
queue=fq-codel
add address=192.168.1.1/24 interface=vlan-ufficio network=192.168.1.0
add address=10.0.0.1/24 interface=vlan-ezio network=10.0.0.0
add address=10.0.0.0/24 dns-server=10.0.0.1 gateway=10.0.0.1
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
/ip firewall mangle
add action=mark-connection chain=forward comment="VoIP Conn" dst-address-list=\
VoipVoice new-connection-mark=VoIP_conn passthrough=yes src-address-list=\
LAN
add action=mark-connection chain=forward dst-address-list=LAN \
new-connection-mark=VoIP_conn passthrough=yes src-address-list=VoipVoice
add action=mark-packet chain=forward comment="VoIP Packets" connection-mark=\
VoIP_conn new-packet-mark=VoIP_packets passthrough=no
add action=mark-connection chain=forward comment="Hyper Backup Conn" \
dst-address=***** dst-port=61281 new-connection-mark=\
hyperbackup_conn out-interface=pppoe-out1 passthrough=yes protocol=tcp
add action=mark-packet chain=forward comment="Hyper Backup Packets" \
connection-mark=hyperbackup_conn new-packet-mark=hyperbackup_packets \
passthrough=no
add action=mark-connection chain=forward comment="Azienda Conn" \
new-connection-mark=azienda_conn out-interface=pppoe-out1 passthrough=yes \
src-address=192.168.1.0/24
add action=mark-packet chain=forward comment="Azienda Packets" connection-mark=\
azienda_conn new-packet-mark=azienda_packets passthrough=no
add action=mark-connection chain=forward comment="Ezio Conn" \
new-connection-mark=ezio_conn out-interface=pppoe-out1 passthrough=yes \
src-address=10.0.0.0/24
add action=mark-packet chain=forward comment="Ezio Packets" connection-mark=\
ezio_conn new-packet-mark=ezio_packets passthrough=no
