One prerequisite is to have wireless package installed on RB4011 (not wifi-qcom-ac ... which drops support for 2.4GHz radio on RB4011 anyway). Then you have to configure things in
/capsman configuration subtree. When everything is configured there correctly, you should be able to put your cAP ac into CAP mode by properly pressing reset button (read
cAP manual). Alternatively you can reconfigure cAP ac into CAP mode via any of UI.
Another option (possibly better) is to install ROS 7.13.2 (it seems to be the best in v7 series so far) on cAP ac ... and replace wireless package with wifi-qcom-ac. In this case you'll have to configure CAPsMAN on RB4011 under
/interface/wifi (all configuration subtree, new capsman uses same profles as new wifi driver). And proceed in the same manner on cAP ac (the reset button magic or manually via UI). This solution will unleash quite some throughput (and stability) on your cAP ac, but it is a realistic possibility of running out of flash storage space ... many reports say that running this ROS/driver combination is fine if device is only used as AP (or CAP), but it's your decision.
If you encounter any problems, come back and we'll try to help sort it out.
