Hammy
Forum Veteran
Forum Veteran
BGP and OSPF
Sat Dec 22, 2007 3:57 pm
So is it the general consensus that Mikrotik finally has BGP and OSPF working well enough to use? I've heard that OSPF has been good for a while, but BGP's completely uselessness killed it. However, I also heard recently that BGP in 2.9.48 was working well and that 3.0 had a complete rewrite and was going to have more features.
Mike Hammett
The Brothers WISP
sten
Forum Veteran
Forum Veteran
Re: BGP and OSPF
Sun Dec 23, 2007 2:00 am
I suspect that BGP in 2.9.50 (on x86) still has some memory issues. Basically what i think is happening is that the bgp process eats more memory as the bgp links are broken and reconnected.
I mean, it works, it just might need a reset every now and again.
Move along. Nothing to see here.
ste
Re: BGP and OSPF
Sun Dec 23, 2007 3:52 pm
I've a 2.9.45 system running BGP/OSPF for 132 days
now without a single problem. BGP Sessions are
52days up.
Uses 220MB Memory with full Internetroutingtable and 2 iBGP
peers now.
System is vmware Server on a P4 2,8GHz using VLAN.
So I feel pretty good with this solution.
It's a matter of using a working Release and not change it then.
Stefan
bokili
Re: BGP and OSPF
Mon Dec 24, 2007 8:40 pm
52days up.
I think that success is in 2.9.45 as we tested it with 2.9.50 and it keep crashing as it use all RAM memory available for 3 days and after every 3 days and few hours it crashes, so we are using Cisco for now.
If somebody can provide link for 2.9.45 it will be excellent. I asked Mikrotik and there is no reply for days. It seems that they won't give this 2.9.45 version.
I have 2.9.44 somewhere on my hdd, so "ste" do you have good results with 2.9.44 ?????
Also, "ste" how much you have of RAM memory installed and if your CPU is Dual Core?
ste
Re: BGP and OSPF
Mon Dec 24, 2007 11:27 pm
52days up.
No. Do not use 2.9.44 for BGP. I've at least 256MB installed. No I've no Dual Core.
Via Epia and normal P4.
Stefan
Gerard
Trainer
Trainer
Re: BGP and OSPF
Tue Dec 25, 2007 7:45 am
bokili,
I have a mikrotik archive at http://www.shelbywireless.com/files/mikrotik/
-Gerard
Certified Mikrotik Trainer
bokili
Re: BGP and OSPF
Wed Dec 26, 2007 9:57 am
"Ste", Possible that we had problem as we used 2GB Ram which 2.9.X doesn't support and maximum working period was 3 days. We will test it soon with 512MB. I asked support and they told that more than 1GB will not be a problem as mikrotik "will use only what is needed" but you never know.
"Gerard" THANK YOU VERY MUCH for link to your archive :)
bokili
Re: BGP and OSPF
Sun Jan 20, 2008 7:58 am
The problem was intel 945 chipset not supported in 2.9.X fully...
Upgrading to v3 fixed problem.
CarulloS
Re: BGP and OSPF
Wed Jan 23, 2008 2:38 am
So now that v3.0 is available has anyone tested and found that this version is stable with BGP / OSPF or both?
I use OSPF on v3 by itself and it seems happy. I would like to move to a MT box that can run BGP and OSPF at the same time with two BGP peers with full tables each. Could I expect success or a supout.rif sent to support?
Thanks,
Scott
believewireless
Re: BGP and OSPF
Wed Jan 23, 2008 2:46 am
We have OSPF and BGP running V3.0 on a router and it's doing fine with full routes. Memory seems stable as well. No BGP resets so far. (4d 19h)
bokili
Re: BGP and OSPF
Wed Jan 23, 2008 2:21 pm
BGP is very stable on v3 final.
Well done mikrotik.
mojiro
Re: BGP and OSPF
Wed Jan 23, 2008 3:42 pm
Because of the several problems (that differ by mikrotik version...) with BGP,
I forward the traffic of all interfaces via vlans to a linux box with Quagga BGP.
Deep to cloud!
bokili
Re: BGP and OSPF
Wed Jan 23, 2008 4:13 pm
You probably done something wrong.
I am sure mikrotik BGP works perfect in V3 final.
mojiro
Re: BGP and OSPF
Wed Jan 23, 2008 4:42 pm
I have not migrate to v3.0 yet. I wish it be stable with BGP. I do not prefer having two pc's.
Deep to cloud!
bluemont
Trainer
Trainer
Re: BGP and OSPF
Tue Feb 26, 2008 6:28 pm
Has anyone tried to run two BGP feeds on two different RouterOS boxes with OSPF in the middle?
If so I would be interested in your settings to try to duplicate it here.
We have tried to get it running here and keep seeing weird issues with the iBGP Sessions and multiple BGP feeds. One feed at a time works without a problem.
Users browsing this forum: Dehale, ngoquocdung, sakirozkan and 138 guests
