My device: RB5009UG+S+
RouterOS 7.14.2
My setup
ISP1: ether8 - DHCP client - Primary
ISP2: ether7 - DHCP client - Backup
Local networks: default VLAN 192.168.1.1/24, guest: VLAN20 10.250.250.0/24
Config export below
Routing table below
I am trying to set up failover on my device so that if ISP1 on ether8 is down, the router switches to ISP2 on ether7. When ISP1 comes back up, the device should switch back to ISP1.
I am using the scripts found at https://gist.github.com/marfillaster/7a ... id=4233415
My problem is:
If I disconnect or bring ether8 down, the device switches to ISP2 ether7. - so all OK there
If instead I simulate an issue on ISP1, where the interface ether8 is still up, but no traffic is being forwarded, the device does not switch over to ISP2 on ether7.
I'm not entirely sure where the problem lies but i suspect the routing table is not being updated properly. When i simulate an ISP issue, there is no change in the routing table and nothing is being logged, so i think the connection issues is not detected properly.
This is my first Mikrotik device, so I am struggling to figure it out.
Code: Select all
add admin-mac=48:A9:8A:AA:D4:AF auto-mac=no comment=defconf name=bridge \
port-cost-mode=short vlan-filtering=yes
/interface vlan
add comment=GuestVLAN interface=bridge name=GuestVLAN vlan-id=20
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.1.100-192.168.1.199
add name=GuestJunkDHCP ranges=10.250.250.100-10.250.250.199
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add address-pool=GuestJunkDHCP interface=GuestVLAN name=dhcp1
/ip smb users
/routing table
add fib name=to_ISP1
add fib name=to_ISP2
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether6 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=sfp-sfpplus1 internal-path-cost=\
10 path-cost=10
add bridge=bridge interface=ether1 internal-path-cost=10 path-cost=10
add bridge=bridge interface=GuestVLAN internal-path-cost=10 path-cost=10 \
pvid=20
set udp-timeout=10s
set discover-interface-list=all lldp-med-net-policy-vlan=1
/ip settings
set allow-fast-path=no
/interface bridge vlan
add bridge=bridge tagged=bridge,ether1 untagged=ether6,GuestVLAN vlan-ids=20
add comment=WAN1 interface=ether1 list=WAN
add comment=WAN2 interface=ether7 list=WAN
add comment=guest interface=GuestVLAN list=LAN
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
192.168.1.0
add address=10.250.250.1/24 interface=GuestVLAN network=10.250.250.0
/ip dhcp-client
add comment="WAN1 - dist 1" interface=ether8 script=":if (\\\$bound=1) do={\\r\
\n \\n /ip/route/set [find where comment=\\\"ISP1\\\"] gateway=\\\$\
\\\"gateway-address\\\"\\r\\\
\n \\n}\\r\\\
\n \\n\\r\\\
\n \\n/ip/firewall/connection/remove [find connection-mark=\\\"ISP1_con\
n\\\"]\\r\\\
\n \\n/ip/firewall/connection/remove [find connection-mark=\\\"ISP2_con\
n\\\"]" use-peer-dns=no use-peer-ntp=no
add comment="WAN2 - dist 10" default-route-distance=10 interface=ether7 \
script=":if (\\\$bound=1) do={\\r\\\
\n \\n /ip/route/set [find where comment=\\\"ISP2\\\"] gateway=\\\$\
\n \\n}\\r\\\
\n \\n\\r\\\
n\\\"]\\r\\\
add address=10.250.250.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=10.250.250.1 \
netmask=24
add address=192.168.1.0/24 comment=defconf dns-server=8.8.8.8,1.1.1.1,8.8.4.4 \
domain=something.something.com gateway=192.168.1.1
set allow-remote-requests=yes
/ip dns static
/ip firewall address-list
add address=192.168.1.0/24 list=local
add address=10.250.250.0/24 list=local
add action=drop chain=forward comment=dropinternalfromGuest dst-address=\
192.168.1.0/24 src-address=10.250.250.0/24
add action=drop chain=input comment=dropinputfromguest src-address=\
10.250.250.0/24
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=accept chain=prerouting comment="bridge access" dst-address-list=\
local in-interface-list=LAN
add action=mark-connection chain=prerouting connection-mark=no-mark \
connection-state=established,related in-interface=ether8 \
new-connection-mark=ISP1_conn passthrough=yes
connection-state=established,related in-interface=ether7 \
new-connection-mark=ISP2_conn passthrough=yes
dst-address-list=!local dst-address-type=!local in-interface-list=LAN \
new-connection-mark=ISP1_conn passthrough=yes per-connection-classifier=\
both-addresses-and-ports:2/0
new-connection-mark=ISP2_conn passthrough=yes per-connection-classifier=\
both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting connection-mark=ISP1_conn \
in-interface-list=LAN new-routing-mark=to_ISP1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ISP2_conn \
in-interface-list=LAN new-routing-mark=to_ISP2 passthrough=yes
add action=mark-routing chain=output connection-mark=ISP1_conn \
dst-address-list=!local new-routing-mark=to_ISP1 passthrough=yes
add action=mark-routing chain=output connection-mark=ISP2_conn \
dst-address-list=!local new-routing-mark=to_ISP2 passthrough=yes
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=\
WAN
add comment=ISP1 distance=1 dst-address=9.9.9.9/32 gateway=ether8 scope=10 \
target-scope=10
add comment=ISP2 distance=1 dst-address=8.26.56.26/32 gateway=ether7 scope=10 \
target-scope=10
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=9.9.9.9 \
scope=10 target-scope=11
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=8.26.56.26 \
add comment=ISP1 dst-address=64.6.64.6/32 gateway=ether8 scope=10
add comment=ISP1 dst-address=208.67.220.220/32 gateway=ether8 scope=10
add comment=ISP2 dst-address=208.67.222.222/32 gateway=ether7 scope=10
add comment=ISP2 dst-address=64.6.65.6/32 gateway=ether7 scope=10
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=64.6.64.6 \
routing-table=to_ISP1 scope=10 target-scope=11
add check-gateway=ping distance=2 dst-address=0.0.0.0/0 gateway=64.6.65.6 \
add check-gateway=ping distance=1 dst-address=0.0.0.0/0 gateway=\
208.67.222.222 routing-table=to_ISP2 scope=10 target-scope=11
add check-gateway=ping distance=2 dst-address=0.0.0.0/0 gateway=\
208.67.220.220 routing-table=to_ISP2 scope=10 target-scope=11
/ip service
set www-ssl disabled=no
/ip smb shares
set [ find default=yes ] directory=/pub
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Somewhere
/system identity
set name=Router
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
add address=time.windows.com
/system package update
set channel=testing
/system watchdog
set auto-send-supout=yes send-email-from=someone@gmail.com \
send-email-to=myself@myemail.com send-smtp-server=smtp.gmail.com \
watchdog-timer=no
/tool e-mail
set from=someone@gmail.com port=587 server=smtp.gmail.com tls=starttls \
user=someone@gmail.com
/tool mac-server
/tool mac-server mac-winbox
And:
Code: Select all
[admin@Router] > /ip/route/print
Flags: D - DYNAMIC; I - INACTIVE, A - ACTIVE; c - CONNECT, s - STATIC, d - DHCP; H - HW-OFFLOADED
Columns: DST-ADDRESS, GATEWAY, DISTANCE
# DST-ADDRESS GATEWAY DISTANCE
DAd 0.0.0.0/0 192.168.33.1 1
0 IsH 0.0.0.0/0 8.26.56.26 1
1 IsH 0.0.0.0/0 9.9.9.9 1
D d 0.0.0.0/0 192.168.8.1 10
;;; ISP2
2 As 8.26.56.26/32 ether7 1
;;; ISP1
3 As 9.9.9.9/32 ether8 1
DAc 10.250.250.0/24 GuestVLAN 0
;;; ISP1
4 As 64.6.64.6/32 ether8 1
;;; ISP2
5 As 64.6.65.6/32 ether7 1
DAc 192.168.1.0/24 bridge 0
DAc 192.168.8.0/24 ether7 0
DAc 192.168.33.0/24 ether8 0
;;; ISP1
6 As 208.67.220.220/32 ether8 1
;;; ISP2
7 As 208.67.222.222/32 ether7 1
8 IsH 0.0.0.0/0 64.6.65.6 2
9 IsH 0.0.0.0/0 64.6.64.6 1
10 IsH 0.0.0.0/0 208.67.220.220 2
11 IsH 0.0.0.0/0 208.67.222.222 1
