miankamran7100
Mikrotik RB4011 and a 1 Gbps Up/Down connection
Tue Apr 09, 2024 11:38 pm
I'm facing a problem I have a Mikrotik RB4011 and a 1 Gbps Up/Down connection. Currently, I can only reach 600 Mbps Down and 250 Mbps Up.
k6ccc
Re: Mikrotik RB4011 and a 1 Gbps Up/Down connection
Wed Apr 10, 2024 12:48 am
How are you measuring that?
I have a RB4011 as my primary router that is directly connected to my fiber ONT via a Gig-E connection. If I test with the speedtest in the router using the high speed test facility generously hosted by TomjNorthIdaho, I consistently get 975 - 990 Mb/s. If I test via my desktop (a couple switches away from the router), it's more like 700 Mb/s.
anav
Wed Apr 10, 2024 1:19 am
/export file=anynameyouwish ( minus router serial number, any public WANIP information, keys etc. )
Moba
Sat Apr 13, 2024 8:02 pm
The 4011 can handle 940 Mbps up and down easily over WAN (max port speed minus overhead), even on newer firmwares with QoS. Something is wrong with your config or your Ethernet cables are really bad...
- check your speed without the 4011
- use a default config
- check your CPU usage per core on the 4011
- post your config and @anav will fix everything
anav
Sat Apr 13, 2024 8:23 pm
I will send you my bill @Moba. ;-P
Moba
Tue Apr 16, 2024 12:22 am
LOL @anav. I guess the OP had trouble finding a suitable name for /export file=anynameyouwish
holvoetn
Tue Apr 16, 2024 9:24 am
For a while we used
/export file=becauseanavsaidso
But it didn't stick long enough ...
erlinden
Tue Apr 16, 2024 9:44 am
:lol:
Users browsing this forum: No registered users and 16 guests
