5009Owner
Mikrotik documentation
Thu Apr 11, 2024 3:33 pm
There was this (ROS-121223-1633-8028.pdf) documentation from Normis available to download. Is it possible to get this updated regularly, let's say every month or so. This is a great file to have when reading offline. And make an announcement for it like for software updates. Thank you!
llamajaja
Re: Mikrotik documentation
Thu Apr 11, 2024 4:11 pm
It should updated after every firmware release. This assumes that the changes incorporated have at that point been properly updated/documented in the official docs.
normis
Thu Apr 11, 2024 5:17 pm
That file is on the front page of the documentation itself https://help.mikrotik.com/docs/display/ROS/RouterOS
llamajaja
Thu Apr 11, 2024 5:26 pm
Updated Rarely is not acceptable.......... Updated version stored upon each firmware release is reasonable as part of your release process. Cant be too demanding, its a pdf.
normis
Thu Apr 11, 2024 5:31 pm
PDF is generated by Atlassian software and is some 100MB big. It is not easy or fast. It is updated every 2-3 months, there are not so many new features during these revisions.
Amm0
Thu Apr 11, 2024 5:57 pm
Think y'all selling yourselves short. ;) And docs themselves do get updated regularly.
Seems like a `cron` job...
llamajaja
Thu Apr 11, 2024 6:07 pm
True that, the website is updated regularly......Okay, given you have opted to create PDF in a cumbersome way ;-), seems like its what we will get so, better than not having it. Thanks.
TheCat12
Thu Apr 11, 2024 10:46 pm
Apart from that, I have a side question - why is the HA Case Studies section blank? It used to have useful information about WAN failover, firewall marking, etc.
normis
Fri Apr 12, 2024 8:48 am
Cron job :D You underestimate Atlassian. It's such a complicated mess.
Amm0
Fri Apr 12, 2024 6:53 pm
Fair enough. I hate Confluence, as user and admin many years ago.
Have you ever looked at AsciiDoc (https://asciidoc.org)? It deals with all the TOC/etc stuff that markdown doesn't. OSS, no Java, and esoteric syntax seems more Mikrotik. Apple uses it for the their new PKL language, https://pkl-lang.org/main/current/standard-library.html
Larsa
Fri Apr 12, 2024 8:59 pm
Well, Jira/Confluence might be perceived as 'messy' in the same way as ROS might be for novices. 😉
These products are complex toolkits capable of doing almost anything but requires solid knowledge and experience to set up effectively. If configured correctly, the environment should be pretty easy for the end-user to use. There are several capable plugins to automate PDF generation, both commercial and free, available at the Atlassian marketplace. Here are some pointers: "Confluence PDF Automation"
If you find it too difficult to do on your own, I recommend contacting some consulting experts at www.atlassian.com/experts. :D
Have a nice weekend!
Users browsing this forum: jaclaz, ogggi and 22 guests
