polandlp
Best choice for vpn gate
Fri Apr 12, 2024 3:40 pm
Hello, I like to set up a vpn gate for ovpn(It must by ovpn no WG or something else). What is best hardware for this? I have 10' rack. It must be not expensive. I chose rb750gr3 its good option?
patrikg
Re: Best choice for vpn gate
Sat Apr 13, 2024 2:23 pm
You missed and mention how many vpn connections you will be running at the same time.
And what speed are we talking about ? Do you need sfp or sfp+ ports.
And there are Mikrotiks Distributors that can provide these figures for you.
https://mikrotik.com/buy
polandlp
Sat Apr 13, 2024 6:57 pm
For max 20 clients and I dont need sfp of sfp+
rplant
Wed Apr 17, 2024 10:25 am
Possibly worth looking at and comments surrounding
viewtopic.php?p=1063801#p1063801
I like the hap ac2, though with current routeros versions you will likely need to disable and remove wifi packages.
Users browsing this forum: No registered users and 14 guests
