ringrring
optimise ax3 Wireless AP
Sun Apr 14, 2024 6:31 pm
I have hAP ax3 wifi connected to a UB5009 router. My house has thick stone walls and some rooms are getting a poor signal with 20MBps from a 1GBps supply to the router, However, sitting right next to the router has 125MBps max on the 2.4 radio.
What options can I have for improving the performance of the wifi? in software and in terms of position and antennae placement. I previously used a linksys MESH w 3 boxes.
My config is below. Many thanks
# 2024-04-25 19:09:58 by RouterOS 7.14.2
# software id = XTHN-KIHA
# model = C53UiG+5HPaxD2HPaxD
# serial number = HFF098RJ21S
add admin-mac=xxxxxxxxxxxxxxauto-mac=no comment=defconf name=bridge \
port-cost-mode=short
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
configuration.country="United Kingdom" .mode=ap .ssid=fa7b34m5 disabled=\
no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
configuration.country="United Kingdom" .mode=ap .ssid=fa7b34m disabled=no \
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=yes interface=bridge lease-time=10m \
name=defconf
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
add interface=ether1 list=WAN
add address=192.168.88.2/24 comment=defconf interface=bridge network=\
192.168.88.0
/ip dhcp-client
192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.88.2 comment=defconf name=router.lan
add address=xxxxxxxxxxxxxxname=upgrade.mikrotik.com
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
established,related,untracked
connection-state=invalid
add disabled=yes dst-address=0.0.0.0/0 gateway=192.168.88.1 routing-table=\
main suppress-hw-offload=no
add comment="Default route" disabled=no dst-address="" gateway=192.168.88.1 \
routing-table=main suppress-hw-offload=no
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/London
/system note
set show-at-login=no
Users browsing this forum: anav, Google [Bot], raiser and 11 guests
