It seems like that this has been removed in CHRs on ROS7. In ROS6 it would always generate false/true based on if it was a CHR or a routerboard.
Does anyone know if this will be brought back in ROS7 or if there is a better way to accomplish it?
I have not been able to find any information why this was removed from ROS7 CHRs.
If you want to test it on your own device you can run:
Code: Select all
:local test [/system routerboard get routerboard]; :put $test
