Dear all,
I thank in advance those who want to give me suggestions.
I would like to try using the Mikrotik router with the iliad fiber in Net-neutrality configuration.
The problem I encounter is that the ipv6 dhcp client remains in
"Status:searching..."
at the second step of point 11 (Click on the “Release” item) of the guide:
https://www.iliad.it/docs/VoIP/Guida_Mi ... e_VoIP.pdf
In fact, I am not sure that I have correctly interpreted the substitutions indicated with (Data available in the personal area), so for completeness I am reporting the data in the personal area,
for any suggestions or corrections of the following configuration:
add name=LAN
add name=WAN
/interface ipipv6
add local-address=IP6_TUNNEL_LOCAL name=ipipv6-tunnel1 remote-address=IP6_TUNNEL_GW
/interface vlan
add interface=WAN name=WAN:836 vlan-id=836
add name=DHCP-LAN ranges=192.168.1.2-192.168.1.254
add address-pool=DHCP-LAN interface=LAN name=DHCP-LAN
/ipv6 pool
add name=ipv6-pool prefix=::/64 prefix-length=64
add bridge=WAN interface=ether1
add bridge=LAN interface=ether2
add address=192.168.1.1/24 interface=LAN network=192.168.1.0
add address=192.168.1.0/24
add dns-server=DNS_V4_1,DNS_V4_2
add gateway=192.168.1.1
add action=masquerade chain=srcnat out-interface=ipipv6-tunnel1 src-address=192.168.1.0/24
add disabled=no dst-address=0.0.0.0/0 gateway=ipipv6-tunnel1 routing-table=main suppress-hw-offload=no
/ipv6 route
add disabled=no dst-address=IP6_NETWORK gateway=WAN routing-table=main
/ipv6 address
add address=IP6_TUNNEL_LOCAL advertise=no interface=ipipv6-tunnel1
add address=::192:168:1:1 from-pool=ipv6-pool interface=LAN
/ipv6 dhcp-client
add add-default-route=yes interface=WAN:836 pool-name=ipv6-pool request=address,prefix
