uebi
Routing Mark Problem/Question for incoming connections
Wed Dec 26, 2007 4:16 am
Hi there!
I'm writing this topic via my routerboard that has 2 internet connections (DSL and Cable, 2 default gateways with different routing marks). I do some marking to do tcp port 80 over the DSL line and everything else over cable. Works fine, I surf the web via the DSL line, do my ssh stuff via the cable connection, send mails through the cable connection, .... but there is something I don't understand...
As soon as I activate the marking, everything works fine and I have something like a "static" load balancing (which is my intention!), but the second this is active, I can no longer ping the WAN IPs??? I have two public IPs, one from my cable provider and one from my DSL PPTP connection, which are both pingable, but only as long as I don't do any marking.
The question is why? Am I missing something? What do I have to configure for incoming connections? Or does my routerboard just want me to got to bed? *G*
Thanks!
Greets,
uebi
"They have the Internet on computers now?" - Homer Simpson
uebi
Re: Routing Mark Problem/Question for incoming connections
Wed Dec 26, 2007 4:22 am
I tried about an hour, than I posted the topic and a few minutes later, I found out that I just have to add the "default" gateway again without a routing mark.
Well, it's far past midnight here ;-)
Thanks,
uebi
PS: I didn't delete the topic, because maybe somebody has the same problem some day. If the admins don't think that way - delete it and punish me in Krakow ;-)
pokeman
Sat Dec 29, 2007 6:48 pm
hi dude
can you post you conf ?
Thanks,
uebi
uebi
Sat Dec 29, 2007 7:35 pm
Sure. Just replaced the IPs and addes some comments.
The 3 routes. I got one more static route for a network I always wanna reach via Upstream1, but I didn't paste it here.
add comment="Gateway for upstream1 markings" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=1.1.1.1 routing-mark=upstream1-traffic scope=30 \
target-scope=10
add comment="Gateway for upstream2 markings" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=2.2.2.2 routing-mark=upstream2-traffic scope=255 \
target-scope=10
add comment="Default Gateway" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=2.2.2.2 scope=255 target-scope=10
Marking. All port 80 and port 53 traffic goes through Upstream1. Everything else through Upstream2.
/ip firewall mangle
add action=mark-connection chain=prerouting comment="All Connections" disabled=no in-interface=bridge1 \
new-connection-mark=all-connections passthrough=yes
add action=mark-routing chain=prerouting comment="Upstream1" connection-mark=all-connections disabled=no dst-port=80 \
in-interface=bridge1 new-routing-mark=upstream1-traffic passthrough=yes protocol=tcp
add action=mark-routing chain=prerouting comment="" connection-mark=all-connections disabled=no dst-port=53 \
in-interface=bridge1 new-routing-mark=upstream1-traffic passthrough=yes protocol=udp
add action=mark-routing chain=prerouting comment="Upstream2" connection-mark=all-connections disabled=no dst-port=!80 \
in-interface=bridge1 new-routing-mark=upstream2-traffic passthrough=yes protocol=tcp
add action=mark-routing chain=prerouting comment="" connection-mark=all-connections disabled=no in-interface=bridge1 \
new-routing-mark=upstream2-traffic passthrough=yes protocol=icmp
add action=mark-routing chain=prerouting comment="" connection-mark=all-connections disabled=no dst-port=!53 \
in-interface=bridge1 new-routing-mark=upstream2-traffic passthrough=yes protocol=udp
Traffic for Upstream1 needs to be masqueraded (dynamic IP), traffic for Upstream2 is natted to my static cable IP.
add action=masquerade chain=srcnat comment="Upstream1" disabled=no dst-address=0.0.0.0/0 out-interface=pptp-upstream1 \
routing-mark=upstream1-traffic src-address=192.168.7.0/24
add action=src-nat chain=srcnat comment="Upstream2" disabled=no dst-address=0.0.0.0/0 out-interface=ether1 \
routing-mark=upstream-traffic src-address=192.168.7.0/24 to-addresses=1.2.3.4 to-ports=0-65535
Hope I didn't forget anything ;-)
Greets,
uebi
pokeman
Sat Dec 29, 2007 11:32 pm
i have 2 dsl 1 is static ip and second is on dhcpd isp assing ip . i make port forwording 8291 to the dsl 1 ether2
simple senario all traffic route to ether3 except 80 on ether1 and i could connect winbox from remote location
i apply this rules based on your rules. this not working make any mistake ??
/ip route print
# DST-ADDRESS PREF-SRC G GATEWAY DISTANCE INTERFACE
0 ADC 192.168.0.0/24 192.168.0.4 ether2
1 ADC 192.168.1.0/24 192.168.1.101 ether3
2 ADC 192.168.10.0/23 192.168.10.1 ether1
3 A S ;;; Gateway for upstream1 markings
0.0.0.0/0 r 192.168.0.5 1 ether2
4 A S ;;; Gateway for upstream2 markings
0.0.0.0/0 u 192.168.1.100 1
5 A S ;;; Default Gateway
/ip firewall mangle
;;; All Connections
chain=prerouting in-interface=ether1 action=mark-connection new-connection-mark=all-connections passthrough=yes
21 ;;; Upstream1
chain=prerouting in-interface=ether1 protocol=tcp dst-port=80 connection-mark=all-connections action=mark-routing
22 ;;; Upstream1
chain=prerouting in-interface=ether1 protocol=tcp dst-port=8291 connection-mark=all-connections action=mark-routing
23 ;;; Upstream2
chain=prerouting in-interface=ether1 protocol=tcp dst-port=!80 connection-mark=all-connections action=mark-routing
24 ;;; Upstream2
chain=prerouting in-interface=ether1 protocol=tcp dst-port=!8291 connection-mark=all-connections action=mark-routing
25 chain=prerouting in-interface=ether1 protocol=icmp connection-mark=all-connections action=mark-routing
/ip firewall nat print
2 ;;; Upstream1
chain=srcnat out-interface=ether2 src-address=192.168.10.0/23 dst-address=0.0.0.0/0 routing-mark=upstream1-traffic
action=masquerade
3 ;;; Upstream2
chain=srcnat out-interface=ether3 src-address=192.168.10.0/23 dst-address=0.0.0.0/0 routing-mark=upstream-traffic
action=src-nat to-addresses=192.168.1.100 to-ports=0-65535
target-scope=10
target-scope=10
/ip firewall mangle
Greets,
uebi
uebi
Sat Dec 29, 2007 11:47 pm
Does your MT have the public IPs assigned to its interfaces and did you just replace them in your post to not show them? Is it a DSL MODEM or ROUTER?
Basically, I have both public IPs directly on my MT (static and pptp) and therefore I don't need any portforwarding/marking/whatever to be able to access the router with winbox from outside my LAN.
Greets,
uebi
pokeman
Sun Dec 30, 2007 12:27 am
thanks dude for your prompt reply
lets assume both are dsl and i forworded 8291 from uplink1 connection ether2 , ether 3 dsl don't have static ip . i hope you understand my question . send me your email i am online right now at msn
Greets,
uebi
pokeman
Tue Jan 01, 2008 9:52 pm
where r u uebi ?
uebi
Wed Jan 02, 2008 12:51 am
Sorry, I was away from my computer.
I don't have MSN here :-(
E-Mail?
Greets
pokeman
Wed Jan 02, 2008 3:40 pm
well i post my issue in my pervious post please read !!!
uebi
Wed Jan 02, 2008 11:47 pm
I already read it, but I'm still not sure why you need a portforwarding for Winbox ON the MT??
Do you have ADSL-Modems (Bridge) oder ADSL-Routers in front of the MT?
I never had any issues getting onto my MT with this config when the public IPs ar ON THE MT, not in front on the ADSL-Router! If your public IPs are configured on your ADSL Router (not the MT!), then you need to configure a DST-NAT on the ADSL-Router to forward the Winbox Port to the private MT IP, but I don't any application where you need a portforwarding ON a MT to access it with winbox.
Greets,
uebi
pokeman
Fri Jan 18, 2008 7:46 pm
hello
hi urbi still this issue not resolve
waiting your reply
Users browsing this forum: TomjNorthIdaho, trofiv and 76 guests
