shalak
Unexpected behavior when finding by variable value
Mon Apr 29, 2024 1:34 am
I have this snippet:
    :put ("HARDCODED: " . [/ip firewall filter find comment="The unique comment"])
    :local comment "The unique comment"
    :put ("VIA VAR:   " . [/ip firewall filter find comment=$comment])
It returns:
HARDCODED: *25
VIA VAR: *43;VIA VAR: *1;VIA VAR: *2;VIA VAR: *3;VIA VAR: *4;VIA VAR: *5;VIA VAR:.... (and so on)
Why is that, why via $comment approach, I'm getting all the rules, not just the one with the comment?
rextended
Re: Unexpected behavior when finding by variable value
Mon Apr 29, 2024 2:01 am
comment=$comment ???
Is not one "Unexpected behavior", it is always idiotic to call variables with the same name as fields, and this is true in all programming languages(*).
# code not fixed / optimized, except for the variable name
    :local notanidioticname "The unique comment"
    :put ("VIA VAR:   " . [/ip firewall filter find comment=$notanidioticname])
comment=$comment
is like
"where item comment is = to the (same) item comment", and obviously is true for all items, so all items are returned.
Amm0
Mon Apr 29, 2024 2:19 am
The solution is don't use the same local variable name as the attribute. See https://wiki.mikrotik.com/wiki/Manual:S ... able_names
So using $comment would be it being nil/[:nothing], and find's matcher with nil is ignore... so it returns them all. And it repeats the "VIA VAR: " multiple times is expected since that how arrays work with concatenation. See https://wiki.mikrotik.com/wiki/Manual:S ... _to_string
Edit: See @rextended's post above - same story.
shalak
Mon Apr 29, 2024 2:33 am
comment=$comment
is like
Thank you!
Is it now?
Let's see:
Python:
the_parameter = "value"
def the_method(the_parameter):
    print(f"Value is: {the_parameter}")
the_method(the_parameter=the_parameter)
Ruby:
  puts "Value is: #{the_parameter}"
end
the_method(the_parameter: the_parameter)
Kotlin:
fun theMethod(theParameter: String) {
    println("Value is: $theParameter")
val theParameter = "value"
fun main() {
    theMethod(theParameter = theParameter)
C#:
using System;
class Program {
    static void Main() {
        string theParameter = "value";
        TheMethod(theParameter: theParameter);
    static void TheMethod(string theParameter) {
        Console.WriteLine($"Value is: {theParameter}");
Swift:
func theMethod(theParameter: String) {
    print("Value is: \(theParameter)")
let theParameter = "value"
theMethod(theParameter: theParameter)
PHP:
function theMethod($theParameter) {
    echo "Value is: $theParameter";
$theParameter = "value";
theMethod(theParameter: $theParameter);
Scala:
object Main extends App {
    def theMethod(theParameter: String): Unit = {
        println(s"Value is: $theParameter")
PowerShell:
function TheMethod {
    param([string]$theParameter)
    Write-Host "Value is: $theParameter"
TheMethod -theParameter $theParameter
R:
theMethod <- function(theParameter) {
  cat("Value is:", theParameter, "\n")
theParameter <- "value"
Lisp:
(defun the-method (&key the-parameter)
  (format t "Value is: ~A~%" the-parameter))
(let ((the-parameter "value"))
  (the-method :the-parameter the-parameter))
Ada:
with Ada.Text_IO; use Ada.Text_IO;
procedure Main is
    the_parameter : String := "value";
    procedure The_Method (the_parameter : String) is
    begin
        Put_Line ("Value is: " & the_parameter);
    end The_Method;
begin
    The_Method (the_parameter => the_parameter);
end Main;
All seem to work just fine... But I guess, you learn something new every day 🤷
Amm0
Mon Apr 29, 2024 5:57 am
LOL, Lisp and Ada examples. Now, RouterOS's logic inherits some from LUA actually, which ver 5(?) supported. I think they created the current language to be more "config centric" than a general-purpose language. All this still has to fit in 16MB flash disks...
If you think all commands are functions, the restriction makes more sense. In a routeros function, named parameters become local variables. So when [find] "function" executes, it has a local $address inside it. And same happens with user functions:
:global fn1 do={
   :return $address
:put [$fn1 address=1.1.1.1]
#output: 1.1.1.1
vs.
:global fn2 do={
   :local address
   :return $address
:put [$fn2 address=1.1.1.1]
#output:  (nothing)
shalak
Mon Apr 29, 2024 11:25 am
:global fn1 do={
   :return $address
#output: 1.1.1.1
vs.
:global fn2 do={
   :local address
   :return $address
#output:  (nothing)
I see, thank you for the insight. I'll be extra careful in future and be aware of the scopes/overshadowing behavior - one can easily shoot themselves in the foot because of all of this.
rextended
Mon Apr 29, 2024 2:37 pm
Is it now?
idiotic != allowed
idiotic <> allowed
internal code for /ip add find where address=$address
internal code
(eval /ip address find
where=$address;$network;$netmask;$broadcast;$interface;$actual-interface;$invalid;$dynamic;$disabled;$comment;$.id;$.nextid;$.dead;(= $address $address);5)
(= item1 item2) is a function that return true is both item have same value.
In this case (= $address $address), so the function return true everytime for obvious reason.
internal code for /ip add find where address=$xxx
internal code
where=$address;$network;$netmask;$broadcast;$interface;$actual-interface;$invalid;$dynamic;$disabled;$comment;$.id;$.nextid;$.dead;(= $address $xxx);5)
This time the address is really compared with $xxx that do not exist in this ambit and is searched on local (then global if not finded) variables.
Users browsing this forum: No registered users and 8 guests
